08-07-2016, 09:54 AM | #1 |
Horn Rod Length
I am putting the Original light switch setup on our truck , I am going to try to lengthen the Horn/Light switch rod , I need to know what length to make it and where to measure from. Also the picture below is one I found on line but mine is just like this
Thank You Billy Last edited by firechief5215; 08-07-2016 at 09:56 AM. Reason: Credit for picture |
08-07-2016, 10:50 AM | #2 |
Re: Horn Rod Length
here you go!
www.whidbeymodelaclub.com |
08-07-2016, 11:17 AM | #3 |
Re: Horn Rod Length
Would the 45 3/4 also fit the switch I have pictured without the bail. it appears to be to short or maybe I have something else wrong Does anyone have a break down picture of the switch Maybe I missing a part, and also thank you for your reply
08-07-2016, 11:38 AM | #4 |
Re: Horn Rod Length
I think the light switch handle you need is A-3616-AR.
Bob |
08-07-2016, 01:25 PM | #5 |
Re: Horn Rod Length
I wonder why the chart doesn't show the first design, A-3616-AR?
Does the second one down in the chart "Gemmer Design" mean ALL 2 tooth steering boxes for 1929? Or is my "F" box a Ford box and uses a different rod? |
08-07-2016, 05:40 PM | #6 |
Re: Horn Rod Length
46-3/4” overall length But where does overall length measure from. If so does anyone have the dimension Thank You Billy Last edited by firechief5215; 08-08-2016 at 04:11 PM. |
08-08-2016, 04:12 PM | #7 |
Re: Horn Rod Length
Does anyone know what the correct length would be
Thread Tools | |
Display Modes | |
