Old 03-20-2013, 07:50 PM   #1
Drive Shaft Dave
Default Bumper end bolts
What size dia, are the bumper end bolts 30 coupe.
Drive Shaft Dave is offline   Reply With Quote
Old 03-20-2013, 07:57 PM   #2
wrndln
Default Re: Bumper end bolts
The bumper end bolts are a special type. They have a webbing kind of thing under the head to keep the bolt from turning when the nut is tightened. I believe all model A's used the same bolts. The heads are painted gloss black I believe. All model A parts supplier carry them,
Rusty Nelson
Old 03-20-2013, 08:36 PM   #3
Drive Shaft Dave
The bolts I have are from Brattons, Diameter wise 3/8 ? Seems like a loose fit in the bumper ends. Thanks for the reply. Are they supposed to be loose?
Old 03-20-2013, 09:11 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
The special carrage type bumper end bolts are 7/16 diameter
Old 03-20-2013, 09:12 PM   #5
SteveB31
SteveB31's Avatar
They are 7/16 and they are loose until tightened.
SteveB31 is offline   Reply With Quote
Old 03-20-2013, 09:31 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
In the Ford parts book --28-37, printed july 1945 the nut is listed as 33927-s7, 7/16 x 20, 1/4 thick, 5/8 across flats
The bolts are 7/16, fine thread
Old 03-20-2013, 09:50 PM   #7
Drive Shaft Dave
Yes , what I have is 7/16. Thanks to all that replied.
