08-25-2021, 07:57 AM | #1 |
throwout bearing
what throwout bearing do you use on a model a if you are using a v8 clutch disc and pressure plate
08-25-2021, 10:09 AM | #2 |
Re: throwout bearing
My Tudor has a lightened flywheel and V-8 pressure plate (three finger) and uses the standard Model A throwout bearing.
08-25-2021, 10:31 AM | #3 |
The model A release bearing and hub will work the V8 clutch cover. Make sure that the clutch disk hub doesn't bottom against the the flywheel/pilot bearing area. Some disks will after flywheel surfacing and it can cause a lot of problems. Use an old input spline to put the the disk up to the flywheel surface and make sure the disk face fully contacts the flywheel surface with a bit more hub clearance to allow for wear on the friction surfaces.
Use an original type 9-inch clutch cover with flyweights and adjustable fingers if you can. Some of the new 8N tractor 9-inch type clutches are crap so avoid them if possible. |
08-25-2021, 11:07 AM | #4 |
My 2 cents is pay attention who mtn the bearing . I’m not saying ones better then the other but I’ve learned the hard way and there’s lots of labor to replace theses bearings
"I can't cry as long as I know the Lord has risen " |
10-18-2021, 08:28 AM | #5 |
Is this the correct bearing for a stock single plate clutch?
10-18-2021, 08:58 AM | #6 |
10-18-2021, 09:00 AM | #7 |
10-18-2021, 09:05 AM | #8 |
2065 is the correct throwout bearing
10-18-2021, 07:35 PM | #9 | |
Also make sure it is mounted the correct direction. Not unkown for someone to put it on backwards.
I know the voices aren't real but damn they have some good ideas! |
