Old 08-31-2021, 09:10 AM   #1
SUHRsc
SUHRsc's Avatar
Default 1932 Wiring - Original??
I'm guessing this wiring was replaced at some point in time but before I pull it out and replace with new, could anyone tell me if this is actually originally the wiring that would have come on the car? In the name of safety I will likely still replace it all as some has deteriorated quite a bit...but I'd like to save it if it is indeed from 1932. I know there are some "wrong" parts on the car. I believe it was fixed up to this state in the 50's.
One of my helpers is preparing the new wiring in the mean time while the other is just ready to GO!. Zach
-WANTED-
Pre-War Speed Equipment
Davies or Morrison Intake Manifold
77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads
SUHRsc is offline   Reply With Quote
Old 08-31-2021, 09:25 AM   #2
rockfla
rockfla's Avatar
Default Re: 1932 Wiring - Original??
I think you already know BUT in picture 4 the more "modern" coil mounted in the inside of the firewall is "DEFINITELY NOT" original OR original wiring!!!!!
Old 08-31-2021, 09:31 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
Hey Zac . my guess is that due to the brighter yellow color on some of the wires, I think this is probably a replacement at some point. My 32 Cabriolet had original wiring and the colors were nowhere near as bright as some on yours. Also, my Cabriolet had been stored inside since 59, so I'm sure it was original. Like you, I replaced it all for safety and reliability. I also used the original "bullet" type connectors and put conductive grease in all of them when I put them together. I'm sure you know that there are at least two different front wiring harnesses - DavidG would know more.
Old 08-31-2021, 09:32 AM   #4
Pat/Ohio
Pat/Ohio's Avatar
Actually, the Model B (4 cyl.) coil was mounted on the inside of firewall. It appears to be a 4 cylinder.
Stay Safe!
Pat
Pat/Ohio is offline   Reply With Quote
Old 08-31-2021, 09:39 AM   #5
SUHRsc
SUHRsc's Avatar
Thank you, guys. Yes this is a 4 cylinder Model-B.
That was my thinking too Dale, but just figured I'd ask as I've not had experience with a 32 that wasn't just a pile of mismatched pieces before. This appears to have not actually even been totally apart or anything and I don't believe most of the mechanicals were ever messed with. Just a repaint, freshen the engine and upholstery at some point likely more recently then the rest.
Thanks!
-WANTED-
Old 08-31-2021, 09:41 AM   #6
deuce lover
deuce lover's Avatar
How about more pics of this mystery '32 roadster?
deuce lover is offline   Reply With Quote
Old 08-31-2021, 10:43 AM   #7
DavidG
DavidG's Avatar
I think that some of the wiring is the original, but it has been modified to such an extent that it is likely beyond saving. (I discount some of the apparent freshness of the colors due to the camera flash.)
Old 08-31-2021, 10:52 AM   #8
SUHRsc
SUHRsc's Avatar
Thanks David!
-WANTED-
Old 08-31-2021, 11:20 AM   #9
rockfla
rockfla's Avatar
Stay Safe!
Pat
I am so focused on our 32 with a V8 that the fact of one being a 4cyl and not having been exposed to one, "obviously" never crossed my "ignorant" mind!!! Blushing with stupidity and mouth full of crow. Sorry guys, once again Dad was right.....Start brain, let warm up to smooth idle....Then engage mouth!!
Old 08-31-2021, 11:33 AM   #10
tubman
tubman's Avatar
All I can add is that my '51 has all of it's original wiring (except for the headight crossover which I replaced) and has led a very pampered life. That being said, the colors on your wiring look better than mine.
Old 08-31-2021, 11:47 AM   #11
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 08-31-2021, 09:12 PM   #12
Lawson Cox
Lawson Cox's Avatar
Twins I presume. Great looking boys, and you're starting them out right.
Old 09-01-2021, 05:40 AM   #13
SUHRsc
SUHRsc's Avatar
Yep, 9 month old boy and girl. Henry and Alice. I'm guessing you can figure out where the name Henry came from...
-WANTED-
Old 09-01-2021, 07:50 PM   #14
Graham Freeman
I think Henry needs a cushion to sit on, he will never see out the windscreen.
Graham Freeman is offline   Reply With Quote
Old 09-01-2021, 09:04 PM   #15
Karl
Karl's Avatar
I like Henry better than Edsel and Alice much better than Clara
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 09-01-2021, 09:16 PM   #16
SUHRsc
SUHRsc's Avatar
Alice was my great grandmother's name. Edsel was a possibility but I couldn't give a kid a name that would end up associated with the god awful cars made later in time. We didn't know if we were having 2 boys, 2 girls, or one of each so we needed to have quite a few options ready.
It's tough to name kids, we knew we wanted old fashion names that would stand the test of time as they age.
-WANTED-
Old 09-01-2021, 09:31 PM   #17
tubman
tubman's Avatar
"Old fashioned" names are real popular where I am, especially for girls. I'll bet I know of a dozen young "Hannah"'s and "Emma"'s
Old 09-13-2021, 05:12 PM   #18
alchemy
alchemy's Avatar
Your next twins can be named Victoria and Woody.
alchemy is offline   Reply With Quote
Old 09-13-2021, 07:13 PM   #19
flatford8
flatford8's Avatar
Sorry......, I know little to nothing about ‘32 wiring.....,but I do know the expression on that little guys face behind the wheel is.....absolutely, 100% friggin’ priceless!!!!!.....you got a couple cuties there!!!........Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 09-13-2021, 07:22 PM   #20
TJ
TJ's Avatar
Spend as much time with them as you can. They do grow up fast. You are also involved in a great family hobby.
Thread Tools
Display Modes
