07-03-2021, 10:07 AM | #1 |
9" rear in a 53 f-100
going to A 9" rear out of an early 60s f-100 , in my 53 f-100 , will this be A direct fit ,width is the same and mounting is the same , what about yoke ,and drive shaft ,
07-03-2021, 10:54 AM | #2 |
Re: 9" rear in a 53 f-100
Drive shaft may or may not work as length needed may be different. Make sure you have 3/4" to 1" free play when you measure. The stock U bolts and spring plates should work along with your stock shocks as I recall.
07-03-2021, 12:07 PM | #3 |
You can bet that the driveshaft and probably u-joint yokes will take some modifications. I've never been lucky enough to get a 100% bolt-in with swaps like this.
BTW: When I built my high-horsepower 32 Coupe (520HP SBC), I put a custom 9" rear in it and needed a custom driveshaft. I ordered mine from Strange - cost a little over $300 - with high quality components and made to order. Thought that was a very good price for a chrome moly custom piece: https://www.summitracing.com/parts/str-u1699 |
07-03-2021, 06:27 PM | #4 |
