Old 08-27-2020, 10:30 AM   #1
Burgamot
Default Papanick still in business?
I found papa nick in the swap meet section that he rebuilds speedometers. Sent him mine and get it back in a timely manner but it sat until I finished my rebuild on my 31tudorr. When I first drove it was off 9mph based on my gps. I have emailed him several times without a response.
Does anyone know if he is still in business?
Burgamot is offline   Reply With Quote
Old 08-27-2020, 10:36 AM   #2
talwrench
Default Re: Papanick still in business?
Try this email; [email protected]
talwrench is offline   Reply With Quote
Old 08-27-2020, 11:08 AM   #3
Bob C
Looks like he hasn't posted in about a month.
Old 08-27-2020, 12:25 PM   #4
McMimmcs
McMimmcs's Avatar
How long did it sit?
McMimmcs is offline   Reply With Quote
Old 08-27-2020, 04:36 PM   #5
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Is it possible that you have the wrong gear on the drive shaft?
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 08-27-2020, 06:18 PM   #6
Synchro909
Synchro909's Avatar
As Neil asks above, you may have the wrong gear in the drive. I suggest you go for a drive - the longer the better and check the distance in your modern car. If the Model A odometer gives the same reading as the modern, it is the speedo part of your instrument that is doubtful. If the distance is different by about the same 9%, it is the drive gear at the bottom end of the cable. Change it (probably by 2 teeth) and you'll be good.
You didn't say whether your speedo was reading high or low so I can't say whether you need more or less teeth on the drive gear. If it is reading slow, you need 2 less teeth. If it is reading fast, 2 less. If you change the gear, be careful to put the new one on facing the same way as the old one was.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 08-27-2020, 06:40 PM   #7
Burgamot
Syncho909 had a good suggestion, I will try it. On the question if was accurate before I bought it as project and never had drove it.
Old 08-27-2020, 08:30 PM   #8
gary678*
Changing the gear is a good idea as mentioned above. On a measured course my speedometer was 5.4% low with a 19 tooth gear. I purchased an 18 tooth gear from one of the vendors and now my speedometer/odometer is spot-on. Rationale is that with one less gear a full revolution is a little faster. Since yours is 9% off a two gear change should make it perfect or almost perfect. The repair is easy, just two bolts. When ordering the gear also order the gasket and lube the gear when installing. Good luck! G.D.
gary678* is offline   Reply With Quote
Old 08-27-2020, 09:12 PM   #9
Randy in ca
Randy in ca's Avatar
He's still active on eBay.
Randy in ca is offline   Reply With Quote
Old 08-28-2020, 08:08 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
GPS has a significant error. Try driving past a radar speed sign in a school zone.
Bob Bidonde
Old 08-28-2020, 08:22 AM   #11
updraught
updraught's Avatar
Both GPS and radar need a constant speed over a significant period of time to be accurate.
updraught is offline   Reply With Quote
Old 08-28-2020, 08:29 AM   #12
McMimmcs
McMimmcs's Avatar
I agree. Put two in the same car and you’ll see that they usually will disagree with one another ! At best It’s a guesstimate.
Old 08-28-2020, 11:25 AM   #13
Bob from Northport
Bob from Northport's Avatar
The comment about radar needing a significant period of time to register is wrong.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 09-11-2020, 01:22 PM   #14
papanick
Hi yes I'm still rebuilding the speedometers just let me know what you need. papanick
[email protected]
papanick is offline   Reply With Quote
