Old 09-01-2020, 09:57 AM   #1
2935ford
2935ford's Avatar
Default Lug Nuts
Who sells correct fitting lug nuts or do I need to find a set of originals? I have a '29 Coupe.
Most re pops I see made today are loose fitting (slightly oversized) on the lug bolt which causes wear on either.
The set I have now are like that.
I have one or two originals that fit as designed but not a complete set.
2935ford is offline   Reply With Quote
Old 09-01-2020, 10:08 AM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Lug Nuts
I got a set of cad plated ones from Berts and they fit as they should.
Old 09-01-2020, 11:04 AM   #3
2935ford
2935ford's Avatar
Thank you.
Old 09-02-2020, 04:45 PM   #4
Pete
Pete's Avatar
I see a post about lug nuts once in awhile and it got me to wondering.
Do people ever check closed end lug nuts for bottoming out before they seat on the taper?
I have also seen reproduction nuts that did not have the counterbore on the leading edge.
Pete is online now   Reply With Quote
Old 09-02-2020, 04:50 PM   #5
Benson
Benson's Avatar
I do not know if people check but Vince Falter has a webpage on the subject.
http://www.fordgarage.com/pages/dangerouslugnuts.htm
Old 09-02-2020, 07:02 PM   #6
Tom Endy
Tom Endy's Avatar
A number of years ago some very dangerous lug nuts were being offered by most suppliers. Most of probably dissipated by now, but some are still around. So be aware.
Tom Endy
Old 09-02-2020, 07:16 PM   #7
Pete
Pete's Avatar
When I was running stock model A wheels I used to use the large pattern race nuts.
They will compensate for slightly oversize holes in the wheel and still center ok.
