Old 07-20-2019, 10:40 AM   #1
Burgamot
Default which radiator
I need to replace the radiator on my 1930 coupe. in reviewing posts i see that good things were said about brattons, snyders and berts. brattons and snyders were $585 for a hd radiator and berts was $795. for a in town driver is berts worth the extra? any one have opinion is bratton or snyder the same as to quality?
Burgamot is offline   Reply With Quote
Old 07-20-2019, 10:43 AM   #2
whirnot
whirnot's Avatar
Default Re: which radiator
Check the number of rows of tubes, and more importantly the fins per inch. Shipping will also play a part.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 07-20-2019, 11:14 AM   #3
SteveB31
SteveB31's Avatar
Bert's radiator is made by Brassworks. 10 fins per inch. $650. In stock.
https://modelastore.com/index.php?ro...roduct_id=3743
Steve @ Bert's
SteveB31 is offline   Reply With Quote
Old 07-20-2019, 11:16 AM   #4
SteveB31
SteveB31's Avatar
https://modelastore.com/index.php?ro...roduct_id=3745
Steve @ Bert's
Old 07-20-2019, 11:35 AM   #5
Norm M
Take a look at Berg's.
www.bergsradiator.com/modela.html
Norm M is offline   Reply With Quote
Old 07-20-2019, 11:45 AM   #6
copgib
copgib's Avatar
I have a new Berg's Radiator and couldn't be happier for my 1930 Coupe. Alittle more expensive but you get excellent quality and dependability. Hugh
copgib is offline   Reply With Quote
Old 07-20-2019, 12:34 PM   #7
30 Closed Cab PU
X2 - Bergs and a cleaned out block/head, have to run a thermostat to get my Truck to run at a decent temp of 160 F.
30 Closed Cab PU is offline   Reply With Quote
Old 07-20-2019, 03:47 PM   #8
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I have Bert's re-cored 4 row of tubes radiator. I have driven my A high in the mountains and at sea level in 95+ degree heat. My A has never gone over 180 degrees with this radiator. I love it!!!
Dick M is offline   Reply With Quote
Old 07-20-2019, 06:26 PM   #9
chrs1961815
chrs1961815's Avatar
I don't think you can go wrong as long as the radiator has the right number of rows and is able to cool efficiently. With that being said, most people I think go for Bergs or Brassworks.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-20-2019, 07:14 PM   #10
mike657894
mike657894's Avatar
ask these guys making hot rod ones for 129 to put the neck in the right spot. https://www.ebay.com/itm/New-Aluminu...fb6910ce9a87cb
mike657894 is offline   Reply With Quote
Old 07-20-2019, 08:12 PM   #11
chrs1961815
What dya get for 128 dollars?
Old 07-21-2019, 09:49 AM   #12
katy
katy's Avatar
https://www.fordbarn.com/forum/showt...light=Aluminum
See post # 16
Old 07-23-2019, 10:37 PM   #13
eagle
eagle's Avatar
https://www.ebay.com/sch/i.html?_fro...iator&_sacat=0
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 07-23-2019, 11:17 PM   #14
jm29henry
jm29henry's Avatar
Brass-works makes a beautiful radiator !!! And you can’t find better people than Steve from Berts
jm29henry is offline   Reply With Quote
Old 07-23-2019, 11:19 PM   #15
jm29henry
jm29henry's Avatar
Also fit is just as important as how it is made and brass work fits well
Old 07-24-2019, 06:29 AM   #16
old31
I put a Bergs radiator in and could not be happier.
100 degree temps at 60 mph for a long period and I stay between 180-190. And it fit right in.
