Old 06-16-2023, 09:00 AM   #1
MattDeAmicis
Default 1946 Super Deluxe Voltage Issue Overcharging
Having some voltage issues with my 46 Super Deluxe. 6 Volt positive ground, rebuilt generator, Stromberg E Fire Electronic Ignition, Pertronix Flamethrower 1.5 ohm coil, Optima Red Top 6V Starting battery. The car was stumbling on acceleration. Put a meter on the battery and only got 6.2 volts or so at idle and also at 1500-2000 rpm. Tested the generator by removing the field wire from the voltage regulator and attaching it to the armature terminal and got a high reading on the ammeter. Concluded that the voltage regulator was bad. Got a new Echlin regulator from Napa and eliminated the stumble. Car runs great now but when I put a meter on the battery at idle it is showing 9 volts steady. The ammeter reads about halfway between the center and CHG. Any suggestions how to fix this? I don’t want to damage my generator or electrical system. Thanks-Matt
MattDeAmicis is offline   Reply With Quote
Old 06-16-2023, 11:09 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: 1946 Super Deluxe Voltage Issue Overcharging
The regulator should be adjustable. Find a local rebuilder and take gen and reg to them.
Paul in CT
Old 06-16-2023, 01:24 PM   #3
Anteek29
Anteek29's Avatar
Yes, your regulator needs adjustment. Mine was set high when I first installed it, so I reset the battery relay's voltage to 7.2 volts. I have a 6 volt system.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 06-16-2023, 01:31 PM   #4
cadillac512
cadillac512's Avatar
Here's a video of the adjustment procedure. You'll be bending the lower spring tab on the winding with the small wire. You need to bend it so the tension on the spring is less...go gently and slowly and have engine speed at 1500 rpm or so. Voltage at the battery terminal of the regulator or at the battery should be set at 7 volts plus or minus .2 volts.
By the way, generators do not charge at low idle, so don't worry about that.
https://www.youtube.com/watch?v=MBHtXMTNUXA
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-16-2023, 01:34 PM   #5
cadillac512
