Old 07-10-2021, 09:52 PM   #1
robert shreveport
Default Restarting the engine
My A has a new engine, but has never been installed in the car. Was built 8 yrs. ago. It was been in my shop with every opening covered with clean rags. I’ve tried without complete success to, turn the engine over and squirt a squirt of marvel mystery oil in each cylinder once a month. It is free and turns over with great compression. It has inserts in the bottom end and a B head. My wife is and has been on me to complete putting it (the car) back together. Will the engine be fine still? Comments please
robert shreveport is offline   Reply With Quote
Old 07-10-2021, 10:02 PM   #2
160B
160B's Avatar
Default Re: Restarting the engine
Engine should be fine. When you install the engine and add oil, remove the distributor and pour 1 quart of oil down the hole, this will put oil in the dipper tray so when you start the engine there will be oil for the rods.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 07-10-2021, 10:29 PM   #3
robert shreveport
It was started for me when I picked it up. Do you suppose I should drain this oil and start over again.
Old 07-11-2021, 09:53 AM   #4
Big hammer
Robert oil is cheap maintenance ! Drain and replace the oil it's been in there 8 years.
get a bigger hammer tap done
Old 07-11-2021, 11:16 AM   #5
robert shreveport
I believe your right, guess I’ll recycle it or use on burning brush.
Old 07-11-2021, 03:01 PM   #6
Aretino
Aretino's Avatar
I use my old model A oil for chainsaw bar lube, and coating garden tools to prevent rusting.
Aretino is offline   Reply With Quote
