Old 02-25-2021, 11:30 AM   #1
Krylon32
Default 42-48 Ford Wheels
Can you run 42-48 Ford wheels tubeless? Going to use some 500X16 Excelsior's.
Krylon32 is offline   Reply With Quote
Old 02-25-2021, 12:32 PM   #2
blucar
blucar's Avatar
Default Re: 40 Ford wheels
Originally Posted by Krylon32 View Post
Can you run 40 Ford wheels tubeless? Going to use some 500X16 Excelsior's.
I wonder? Why do you want to use '40 Ford 16" wheels? Ford offered the 5 on 5.5 16" wheels on the F-1/F100 through 1966. This wheel has the inside knobs for the hub cap and looks exactly like the '40 wheel, and are made for tubeless tires.
Bill.... 36 5 win cpe
Old 02-25-2021, 12:34 PM   #3
skidmarks
skidmarks's Avatar
Because....40 is 4" wide and if your lucky and find 40 v8-60 they are 3-1/2" wide.
All others 4-1/2" wide and some were 5" wide
Has to do with skinny tires and the right look
As far as tubeless, ive had some no issues other leaked at the rivits. The tire shop will say its a no no because of no safety bead
skidmarks is offline   Reply With Quote
Old 02-25-2021, 04:25 PM   #4
LSGUN
LSGUN's Avatar
Yeah I would definitely put some silicon on the rivets to prevent leaks.
LSGUN is offline   Reply With Quote
Old 02-25-2021, 04:31 PM   #5
Krylon32
Default Re: 42-48 Ford Wheels
I wonder if powder coating the wheels would seal the rivets?
Old 02-25-2021, 04:40 PM   #6
Will D
Will D's Avatar
That just might work! Seen threads on here of guys using jb weld on the rivets to go tubeless.
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 02-25-2021, 04:54 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
These pictures show 5.50 X 16" Excelsiors on 4", '40 wheels. No tubes, but cautiously buttered the rivets with JB Weld...never a leak! The big ones are 7.50 X 16" Excelsiors on 4-1/2", '48 wheels...no tubes. All on the same '36 3-W.
DD
Click Links Below __
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 02-25-2021, 09:11 PM   #8
Krylon32
I bought some 18 X5.5 40 style steelies from Steadfast MFG for the rear so I know they won't leak and they are still searching for some matching 16 inch fronts. They will look good black with rings and caps on my deuce Henry highboy.
Old 02-25-2021, 09:21 PM   #9
dono50
dono50's Avatar
Send a message via MSN to dono50
V8coopman, the undercarriage detailing is impressive
dono50 is offline   Reply With Quote
Old 02-25-2021, 09:43 PM   #10
32phil
I have Coker classics on 16 X 5 41 Lincoln wheels in the rear and
16 X 4 40 Ford wheels on the front of my 32 Tudor.
No Tubes, I used Metal valve stems So far no leaks
Just about 75 miles on them now.
I guess we'll see how they do this season.
Putting together another set for my 5 window same exact wheel/tire combo.
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 02-25-2021, 10:00 PM   #11
Tim Ayers
The tires he wants to use is a radial I believe.
Tim Ayers is online now   Reply With Quote
Old 02-26-2021, 12:58 AM   #12
V8COOPMAN
V8COOPMAN's Avatar
dono50 .....I probably can't take any credit for that sweet little ride. It belongs to my friend and fellow 'Barner "Heard", who lives and plays just southwest of Daytona Beach. I know he will appreciate your kind words. The top side of his '36 below! DD
T5 W/TORQUE TUBE
