Old 01-17-2021, 03:24 PM   #1
ford35lh
Default The Right Stuff
Has anyone used Permatex Right Stuff ???
Is it just a repackaged other product ???
Pros and cons ???
ford35lh is offline   Reply With Quote
Old 01-17-2021, 03:31 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: The Right Stuff
The stuff is actually a lot better than anything else I have used. Its expensive but when I use it its for some extremely demanding application. Example I use no gaskets on some of my race engines especially in the oil pan and timing cover area the Right stuff can take this abuse and seal everything nicely.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 01-17-2021, 03:34 PM   #3
skidmarks
skidmarks's Avatar
Ive used it on transmission counter shafts and works good
skidmarks is offline   Reply With Quote
Old 01-17-2021, 05:17 PM   #4
cadillac512
cadillac512's Avatar
As posted,it is a very good sealer and not just a repackaged clone. Right Stuff, when used on clean dry parts (as it should be) is seriously strong. You may well have a difficult time getting some stuff back apart so be sure to keep that in mind.Not that it's impossible to remove, but it is very tenacious.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 01-17-2021, 06:17 PM   #5
Hal Beatty
Hal Beatty's Avatar
Not cheap, but good stuff...
Hal Beatty is offline   Reply With Quote
Old 01-17-2021, 06:29 PM   #6
Alaska Jim
Alaska Jim's Avatar
There is a reason it is called "the right stuff". It is in my opinion the best on the market.
Alaska Jim is offline   Reply With Quote
Old 01-18-2021, 06:00 AM   #7
McMimmcs
McMimmcs's Avatar
my mechanic saves it for special jobs only. Not cheap!
McMimmcs is offline   Reply With Quote
Old 01-19-2021, 11:05 AM   #8
Wat-0
Wat-0's Avatar
The guys in my shop have used The Right Stuff for some time on all of my Diesel Trucks, Quality only hurts once!
Wat-0 is offline   Reply With Quote
Old 01-19-2021, 11:08 AM   #9
Firepower flyer
Firepower flyer's Avatar
I've been using it on my last couple engine rebuilds. It's a very good product I've had no leaks on any of them. I find it much better than RTV
Firepower flyer is offline   Reply With Quote
Old 01-19-2021, 11:17 AM   #10
bobH
I once had a customer with aftermarket v/c's on a sbc. Store-bought gaskets didn't fit, and leaked bad. I made the complete 'gasket' out of Right Stuff, it sealed perfectly, never leaked again. Very convincing experience.
bobH is offline   Reply With Quote
Old 01-19-2021, 11:17 AM   #11
tubman
tubman's Avatar
Would this be a good product to use on head bolts/studs?
Old 01-19-2021, 12:30 PM   #12
flatrod
flatrod's Avatar
We used to use it on Chevy head bolts, or any other bolt/stud into water, works great! No seeping head bolts after we went to it.
flatrod is offline   Reply With Quote
Old 01-20-2021, 05:37 PM   #13
tinkirk
tinkirk's Avatar
We used it for header gaskets on roundy round car works great
It's the best stuff I've ever used a little bit pricey but will worth it
tinkirk is offline   Reply With Quote
Old 01-27-2021, 11:22 AM   #14
Royal Ryser
Is this the same stuff recomended for attaching new running board rubber to the metal running board?
Royal Ryser is offline   Reply With Quote
Old 01-27-2021, 11:36 AM   #15
Grease348
Grease348's Avatar
I used it on a B.B. Chevy intake manifold at the block about five or six years ago no problems
Grease348 is offline   Reply With Quote
