Old 10-16-2020, 11:09 AM   #1
AL in NY
AL in NY's Avatar
Default 35 Ford Hubcaps
I recently installed 35 Ford wheels on my 30 CCPU. I purchased new hubcaps from Snyder's that fit reallllllly well. The problem is these hubcaps are extremely hard to remove. Is there a special tool that Ford sold to remove these hubcaps without marring the paint/powder coat finish on the wheels?
AL in NY
AL in NY is offline   Reply With Quote
Old 10-16-2020, 01:15 PM   #2
Sunnybrook Farm
Sunnybrook Farm's Avatar
Default Re: 35 Ford Hubcaps
Wood wedge or one of those plastic (really strong) ones that Stihl sells for driving in a tree. Just something to get it started to where you can grab it.
Sunnybrook Farm is offline   Reply With Quote
Old 10-17-2020, 08:09 AM   #3
Pat/Ohio
Pat/Ohio's Avatar
I use the yellow plastic bondo spreaders you pick up at swap meets etc. Place the thin edge between the hubcap and wheel then use a flat screwdriver to pry against the yellow spreader. Have done this for years with no paint chips etc.
Pat
Pat/Ohio is offline   Reply With Quote
Old 10-17-2020, 08:21 AM   #4
30 Closed Cab PU
Pat
Nice method Pat, kinda like using wide putty knives to protect drywall/trim when prying kick boards/mop boards/trim off drywall. Going to try this instead of my method above, next time.
30 Closed Cab PU is offline   Reply With Quote
Old 10-17-2020, 01:58 PM   #5
1931 flamingo
1931 flamingo's Avatar
Harbor Freight has a set of plastic tools, so I'm told.
Paul in CT
Old 10-17-2020, 02:50 PM   #6
CA Victoria
CA Victoria's Avatar
HF sell a hard plastic tool, this one came from a Swapmeet it is 1” wide w/a double taper and a sharp edge to get into the seam.
Works well-
File Type: jpg 13CD3E0A-AF8E-4B61-8B4B-5E8202371A35.jpg (46.9 KB, 23 views)
File Type: jpg 6C1AF65F-5AB3-4C8D-8C94-887DC3C25FA7.jpg (27.2 KB, 21 views)
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 10-17-2020, 03:43 PM   #7
McMimmcs
McMimmcs's Avatar
Pat
A well tested procedure.
McMimmcs is offline   Reply With Quote
Old 10-17-2020, 05:58 PM   #8
AL in NY
AL in NY's Avatar
Looks like I'll take a ride the HF and pick up these plastic wedge tools.
AL in NY
Old 10-17-2020, 06:10 PM   #9
McMimmcs
McMimmcs's Avatar
And while you’re at it a big thanks to Pat in Ohio for a great tip !
Old 10-17-2020, 11:06 PM   #10
daveymc29
daveymc29's Avatar
I use a 3 or 6 inch putty knife and a screw drive, putty knife in place between tire and rim, a little pull outward and if the cap doesn't move right away I then shove the screw driver between the cap and putty knife. Haven't hurt my powder coating in twenty years. Rubber hammer to refit.
daveymc29 is offline   Reply With Quote
Thread Tools
Display Modes
