Old 08-07-2015, 08:47 AM   #1
aermotor
Default Door windows
How do you get the glass out of the 28 Tudor doors? Got the rear glass out with no problem.
aermotor is offline   Reply With Quote
Old 08-07-2015, 08:49 AM   #2
Mitch//pa
Default Re: Door windows
did you remove the top door plates held in by the 3 screws....
the glass will then slide / lift right out
sometimes the screws can be seized somewhat
i use an impact driver now and then but also had them snap not a big deal.. i think some of them were brass
Old 08-07-2015, 09:19 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I've had to heat the 3 screws for the top plate 2 or 3 times before I could get them out. I also like to use the impact driver Mitch mentioned.
Old 08-07-2015, 10:19 AM   #4
aermotor
Thanks guys - both windows are now out.
John
