Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 06-05-2010, 12:48 AM   #1
G32
Default 1940 Sedan Delivery Rear Door Latch
City: Tulsa
State: OK
Need 40 SD rear door latch.
What is difference in 41 SD latch?
Would consider complete 40/41 SD rear door.
Gene
G32 is offline   Reply With Quote
Old 06-06-2010, 04:16 PM   #2
Pewsplace
Default Re: 1940 Sedan Delivery Rear Door Latch
The doors and latches are different on a 40 and 41. They both will fit either models. The difference is the 40 latch comes off the back and is mounted on a plate. The door panel has no access hole to repair the rear door.
The 41 door latch is mounted inside the door and has no latch panel that comes off. The door has an access panel in the middle to repair any damage and remove the latch. Original ones are difficult to find so keep trying. If building a hot rod, use a bear claw. Hope this helps. I have pictures of the above if required. PM for pictures.
Pewsplace is offline   Reply With Quote
