Old 04-05-2021, 09:46 PM   #21
dmsfrr
dmsfrr's Avatar
Default Re: 272 oil pump prime
Originally Posted by paul2748 View Post
Make sure the shafts are installed correctly so the oil holes in the stand/shaft matches the oil hole in the head
JSRTUDOR,
image, just FYI
Old 04-06-2021, 05:29 AM   #22
darrell
you can tell if the shafts are on right at a glance.if the overflow pipe is at the front on the pass side and the rear on the drivers they are correct.
darrell is offline   Reply With Quote
Old 04-06-2021, 06:28 AM   #23
KULTULZ
KULTULZ's Avatar
Post Re: 272 oil pump prime
... crank the engine over to see if you're getting oil out of the pump
Best not to spin an engine (starter motor) if dry (hard on components) or if a fresh engine has cam lube. The cam lube will be wiped off.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 04-08-2021, 04:46 PM   #24
JSRTUDOR
JSRTUDOR's Avatar
Thanks again Barners! You guys and gals are a God send.
JSRTUDOR is offline   Reply With Quote
Old 04-09-2021, 10:52 AM   #25
JSRTUDOR
JSRTUDOR's Avatar
Thanks again! On to the next problem area!
