Old 11-27-2019, 07:55 PM   #1
34fordpickup
Default 1934 pickup
I'm looking for a 1934 v8 1/2 ton pickup transmission floor cover Eckler's states in there catalog theirs fits a 34 pickup but from personal experience it doesn't come close to fitting. I can't find one anywhere online. Does someone at least have a picture of one or have a line on one?
34fordpickup is offline   Reply With Quote
Old 11-27-2019, 08:27 PM   #2
Scott/Mn
Scott/Mn's Avatar
Default Re: 1934 pickup
34pu- here is a photograph of the original cover for my pickup. Also a battery cover and spacer for pedals and steering tube.
Scott/Mn is offline   Reply With Quote
Old 12-01-2019, 10:31 PM   #3
jerryf
Great pic. Does the trans cover attach to a wood floor or is it metal like the toe board? Thanks for any info. Jerry 817-991-8263
jerryf is offline   Reply With Quote
Old 12-02-2019, 12:58 PM   #4
Scott/Mn
Scott/Mn's Avatar
Jerry, the floor in my truck is mostly plywood with a transverse metal "toe board" in front, both secured by countersunk machine screws.
The metal transmission cover (pictured) has some woven fabric type anti rattle material around the periphery underneath, but is held in place only by the floormat. The metal battery cover is secured by two wood screws.
The floor in the compartment beneath the seat cushion is all metal, and not removable.
Old 12-02-2019, 10:36 PM   #5
jerryf
Thank you. Your picture and explanation is very helpful.
Old 12-05-2019, 11:01 PM   #6
al's28/33
al's28/33's Avatar
My trans cover has two holes on each side and one on the end with slotted head screws to secure it to the floorboard. The battery cover is the Model "A" type with the underside
pressure spring bars.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 12-06-2019, 07:23 AM   #7
DavidG
DavidG's Avatar
Al's28/33 set up is as original. The two holes in the battery cover plate weren't for attachment purposes, but rather to facilitate it being placed on a hook on a conveyor line for dip painting as it is so written on the original engineering drawing (it is a carryover Model A part). The transmission cover was securely attached with flat head slotted wood screws and countersunk washers to ensure that it was properly positioned and not touching the shift lever housing or hand brake handle.
Old 12-07-2019, 12:56 PM   #8
Scott/Mn
Scott/Mn's Avatar
Here are some photos of the battery cover referred to above. The cover allows access to the battery terminals, however the wood floorboard must be removed in order to take the battery out (not a difficult job). Not certain why my transmission cover has no attachment points- it is obviously an old replacement or reproduction.
If anyone has an original floormat for 33-34 pickup please consider posting a photo.
Old 12-07-2019, 04:31 PM   #9
al's28/33
al's28/33's Avatar
My floormat is a modern rubber matt that I custom fit to slide up under the firewall insulation and very neatly trimmed along the doors, kick-panels and front seat riser. It was a bear to fit, even after making a template first.
Old 12-07-2019, 09:54 PM   #10
DavidG
DavidG's Avatar
On further thought (and research) I believe that Ford deleted the screw attachment and therefore the holes in the cover plate as a cost savings running change during the '34 model year.
Old 12-23-2019, 04:26 AM   #11
JD
That is interesting as the transmission cover plate in my 34 pickup also has no holes drilled in it for screws.
JD is offline   Reply With Quote
Old 06-12-2022, 06:47 PM   #12
beneckart
On the battery cover post, one of your images you have a tape but not on the other. Is there a way you could post the length and width measurements for the cover.
beneckart is offline   Reply With Quote
Old 06-12-2022, 07:02 PM   #13
DavidG
DavidG's Avatar
The battery cover plate is a carryover Model A part. Snyder's offer an excellent reproduction under license from Ford.
Old 06-12-2022, 07:10 PM   #14
beneckart
On the 1934 pickup battery cover. On one of the images you have a tape but not on the other. Is there a way you could send me the length and width measurements for the cover.
Old 06-12-2022, 08:55 PM   #15
Charlie Stephens
I see a lot of ads from this guy on Fordbarn, you might give him a try.
[email protected]
Charlie Stephens
Old 06-13-2022, 01:02 PM   #16
beneckart
Thanks. I have talked to him. I am just trying to verify that the 32 pickup battery cover is the exact same as the 34 pickup. So far I have had been getting that they are. But I just want to verify before I buy one.
Ben Eckart
