Old 01-11-2018, 01:21 PM   #21
Kohnke Rebabbitting
Default Re: Rear main oil return tube
Originally Posted by George Miller View Post
Dave is right on. I also drill the oil passage also very important. You never know what you are going to find in that hole. Plus it fixes the tube from blocking the oil flow through the cap, if it is screwed in to far.
"Always"
Kohnke Rebabbitting is offline   Reply With Quote
Old 01-12-2018, 12:34 PM   #22
Beater
Beater's Avatar
drill the oil passage? sorry maybe a dumb question. never had one apart yet. which passage are you drilling out and cleaning?
Beater is offline   Reply With Quote
Old 01-12-2018, 12:41 PM   #23
Dave in MN
Dave in MN's Avatar
You remove the "galley" plug and then drill out the passage that runs along the bottom of the cap from front to rear. Use a 3/8" drill.
I will add some photos to my previous post late tonight of the process.
Good Day!
Dave in MN is offline   Reply With Quote
Old 01-12-2018, 06:09 PM   #24
Beater
Beater's Avatar
photos pleas that would be great
Old 01-16-2018, 07:14 PM   #25
Kohnke Rebabbitting
Pictures:
Old 01-17-2018, 01:42 AM   #26
California Travieso
Send a message via Yahoo to California Travieso
If increasing the oil return tube increases the oil flow, is it a good idea to also replace the stock oil pump with a high flow oil pump that some of the suppliers sell or modify the stock one?
David Serrano
California Travieso is offline   Reply With Quote
Old 01-17-2018, 04:05 AM   #27
Tom Wesenberg
Tom Wesenberg's Avatar
David Serrano
No, the stock pump gives all the oil the engine can use, and then some.
Old 01-17-2018, 12:18 PM   #28
California Travieso
Tom,
Thanks for the information.
David Serrano
Old 01-17-2018, 01:09 PM   #29
Beater
Beater's Avatar
ok I see I think now drill out the length ways passage aswell to a larger size ive not had an A apart yet so thanks this helps lots. is that a lead or babbet cap that goes back on the end?
Old 01-17-2018, 10:20 PM   #30
Dave in MN
Dave in MN's Avatar
Steel galley plug.
Old 01-17-2018, 11:47 PM   #31
Beater
Beater's Avatar
ok and these plugs are available through regular supplyers ?
Old 01-18-2018, 08:49 AM   #32
Dave in MN
Dave in MN's Avatar
Save the plug when you remove it; they can be re-used. If it is a loose fit, place the plug on an anvil and strike it with a hammer. The strike will flatten it and expand it at the same time.
New plugs are available at some suppliers. Snyder's has them.
A-6327-PL $1.00 / ea.
Old 01-18-2018, 11:34 AM   #33
Beater
Beater's Avatar
thanks very much
