Old 08-05-2015, 02:17 PM   #1
Jwilli
Jwilli's Avatar
Default No plug wires No problem
Just use whatever you have.
Jwilli is offline   Reply With Quote
Old 08-05-2015, 02:24 PM   #2
Tinker
Tinker's Avatar
Default Re: No plug wires No problem
Barbed wire...
https://www.youtube.com/watch?v=qudpRXZE3Yo
Old 08-05-2015, 02:33 PM   #3
Jwilli
Jwilli's Avatar
Tinker, I wanted to use some barbed wire, but I did not have any. "A" engines will run on just about anything.
Old 08-05-2015, 03:00 PM   #4
John Stone
John Stone's Avatar
I've seen'em run on a piece of rubber tubing from the coil to the distributor.
Have used barbed wire on the spark plug when a connector breaks in the farm land.
John Stone is offline   Reply With Quote
Old 08-05-2015, 04:55 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Piano wire or a skinny Guitar string is FUN, looks as if it's NOT THERE!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-05-2015, 05:08 PM   #6
Jwilli
Jwilli's Avatar
Great suggestion Bill. I will try that.
Old 08-05-2015, 05:40 PM   #7
mshmodela
mshmodela's Avatar
Excellent McGiver Job! I had a 79' VW scirocco and the ground battery cable connector fell off and the car died as I was going about 60 (I was 20yrs at the time) ... I discovered the MIA ground cable clamp and to get home I yanked my speaker wire and made several loops of it to make a make-shift ground... It worked for 25 miles and got me home
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 08-05-2015, 09:11 PM   #8
Tinker
Tinker's Avatar
Never seen a paper clip but I'm fairly new.
Guess carrying bale wire back then was like duct tape today.
Old 08-05-2015, 09:20 PM   #9
SeaSlugs
SeaSlugs's Avatar
I had to fix the clutch on my s10 with a paperclip...always unsettiling when you push the clutch pedal, hear a bang, and the pedal is just swinging free as a swing and its still in gear...in the city...
soo found a parking spot and shut the truck off at the right time, wrapped paperclip around the shaft as the plastic retainer disintegrated. Drove the 4 hours home and that was 5 years ago... i should probably properly fix that soon...
model A related i bought a buncha stuff and had some sparkplugs with brass straps attached to the top. someone cut up a brass trophy tag and used those as wires!
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-05-2015, 11:09 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Take an ordinary pencil and cut it to length, then sharpen both ends and tie it to the distributor and spark plug. Now you have a carbon wire.
In the 60's our family toured the Corning Glass Works in New York and saw a light bulb screwed into what looked like ordinary clear glass, but it was lit up. Need to find some of that special glass and tie it in place to fire the plugs.
Old 08-05-2015, 11:43 PM   #11
racingrufus
racingrufus's Avatar
When I was in high school I had some rube steal my coil wire. I made one from a wire coat hanger, it got me home. Dwayne
racingrufus is offline   Reply With Quote
Old 08-06-2015, 03:21 AM   #12
russcochiolo
russcochiolo's Avatar
A powered dune buggy in the '50's at Pismo. Lost the coil wire in the sand dunes. Used the hem from a t-shirt dipped in the radiator. Worked until it dried out. Re-dipped until we got home.
russcochiolo is offline   Reply With Quote
Old 08-06-2015, 08:13 AM   #13
jimvette59
jimvette59's Avatar
Lets keep the rat crap off this site. JMHO.
jimvette59 is offline   Reply With Quote
Old 08-06-2015, 08:41 AM   #14
fiddlybits
fiddlybits's Avatar
You have a strange definition of rat crap.
I call it creative thinking to get you home in a bind.
fiddlybits is offline   Reply With Quote
Old 08-06-2015, 09:00 AM   #15
Roadster Rich
Roadster Rich's Avatar
I also used a coat hanger. In college, on a trip from Troy, NY to Burlington VT, all of a sudden it started running awful and no power. One of the copper connectors was gone. I took a coat hanger from the clothes I had and used that. Back then you could not just order parts on the internet, so I used the car this way for about 8 weeks until I could get back to Vermont and pick up the right parts from Hemmings. Never knew the difference.
Roadster Rich is offline   Reply With Quote
Old 08-06-2015, 09:12 AM   #16
james hitchcock
james hitchcock's Avatar
Wow Russ. The t-shirt hem dipped in the radiator takes the prize. I would have never thought of that. Bravo.
james hitchcock is offline   Reply With Quote
Old 08-06-2015, 11:19 AM   #17
BILL WILLIAMSON
Someone mentioned a vacuum hose for a coil wire, Apparently they have a lot of Graphite in the rubber.
Bill W.
Old 08-06-2015, 01:58 PM   #18
30ccpickup
30ccpickup's Avatar
Here is a distributor cap made from a price of wood and fencing wire.https://m.youtube.com/watch?v=g-IJqACbBgs
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
