03-10-2011, 07:42 PM | #1 |
passenger tail lamp addition (safety Q)
I would rather not permanently add a tail light to the passenger side. In that situation do most folks just stick with one, or add some type of a temporary tail lamp attached to the bumper?
03-10-2011, 08:10 PM | #2 |
Re: passenger tail lamp addition (safety Q)
I purchased AA battery powered, magnet mounted lights with 32 LEDs that do a nice job when highway driving.
03-10-2011, 10:14 PM | #3 |
You have a teacup tail light car. Would you think any less of it if the original owner had gone back to the dealer 6 mo after buying it and said " put a light on the other side for safety sake". Put the light on permanently for safety sake and adopt that senario. Bill G
03-11-2011, 03:06 AM | #4 |
I agree with Bill. Unless you are showing your car I would not drive a Model A around with the one tail light. Properly done, the second light quickly looks like it belongs there. I would also suggest going to LED's......then you are really much better off than the stock one light.
03-11-2011, 03:48 AM | #5 |
Magnet?
03-11-2011, 07:21 AM | #6 |
Hi Mike, Yes, it is a $17 lamp with two two inch magnets that I put on after, say a night parade where I have to drive on LIE or parkways for an hour or more at night, just to brighten things up when I am doing fifty and THEY are doing seventy. I hang two of them at those times. Some just trust the magnet on the bumper, but I ad a zip tie for extra assurance. Yes, I also have LED taillites and a third brake lite. |
03-11-2011, 07:49 AM | #7 |
I mounted two rectangular trailer lights under the body. They are not very visible if you are standing right behind the car, but at normal driving distance they are very visible, and are large enough to be easily seen. I use the original light as a tail light and licence plate light, and the underbody lights as tail lights, stop lights, and turn signals. It was cheap, and very visible when needed, without drilling the fender.
03-11-2011, 08:08 AM | #8 |
Search "wireless trailer lights" on your computer. I saw some at TSC the other day I didn't pay too much attention to them so I don't know if they will work with 6 volt system or not. Might be an option. Clyde
03-11-2011, 08:15 AM | #9 |
I like the LED strip-lights, such as the one made by Brakeliter...
I have one mounted on suction cups in the rear window of my Coupe Personally, I believe that the high-mounted center stoplight is more effective in today's traffic... Besides being small and somewhat dim, the OEM lights are placed rather low on the body... a rear-window mount gets that bright LED light "up in the face" of the driver behind you... I like Vince's center-mount ( see link in #6 ), but if it were my car, I would put it up high in the spare tire, again favoring the "in your face" approach. Let's face it - many modern drivers are "distracted", and the remainder are just not very bright... I would like a more "period" looking envelope for my LED strip-light, but until I find / make one, the Brakeliter strip in the rear window is a good solution for me... |
03-11-2011, 08:40 AM | #10 |
03-11-2011, 10:56 AM | #11 |
It's really the drilling of the fender that I would prefer avoiding. The suggestions are very much appreciated.
03-11-2011, 11:14 AM | #12 |
If after you get the correct bracket for the right hand side, mask off the location where the light should be located......measure and re-measure, to be sure everything is positioned perfectly, you should'nt have a problem. I know your apprehension well, as I experienced the same feeling when mounting the right hand light on our Town Sedan. After you have centrer punch marked and drilled the pilot holes....use a step drill, to inlarge the holes to the correct size. Three for mounting, one for the tail light wire.
03-11-2011, 11:47 AM | #13 | |
Can't blame you there... The Brakeliter LED strip-light attaches to the rear window either with suction-cups or double-stick tape. It also has the LED array split into left & right halves, so you can wire a number of ways - including turn-signal function. I have mine set-up as just a full-width stop-light strip. I was toying with an idea similar to Vince's (mounting a center-stop light on the rear spare), but I was thinking of revamping an old Model T headlight I have in the garage, putting some red theatrical gel and maybe a sheet of "Frost" behind the glass headlight lens... might do this yet... |
03-11-2011, 12:25 PM | #14 |
Do you have yours at the top or bottom of your rear window? I am planning on putting one on my '31 PU, just wasn't sure what the best location would be.
03-11-2011, 01:01 PM | #15 | |
I have seen them at AAA Travel Centers. They are called BLAZER LED EMERGENCY LIGHTS on the Internet. I see they sell for a wide range of prices as follows. http://www.google.com/products/catal...ed=0CCkQ8wIwAg# |
03-11-2011, 01:03 PM | #16 |
I also really want a passenger side tail light but am hesitant to take a drill to the fender. Its not show car but just about everything has survived 80 yrs without a single hole drilled for heaters or accesories, etc... Although im making an exception next week to install the seat belts. I currently run the brakelighter strip in the rear window but truly feel the passenger light is needed though, at the very least for symetry. Im hoping to make a bracket this summer so I can mount it to where the bumper support attaches to the frame and have the light in the approximate symetric location. Its probably going to look like crap and i'll end up drilling it in the long run but worth a shot.
Bob NJ |
03-11-2011, 01:03 PM | #17 |
I mounted my LED strip light at the top of the window on my 1930 coupe, so that it could be seen when the rumble seat is open. I often carry passengers, usually a pair of large stuffed bears, but sometimes people. I removed the inside rear window garnish moulding and ran the wires beneath it and behind the rear upholstery panel. I also mounted an aftermarket tail and stop light on top of my folded trunk rack.
03-11-2011, 01:49 PM | #18 |
"I also really want a passenger side tail light but am hesitant to take a drill to the fender. Its not show car but just about everything has survived 80 yrs without a single hole drilled for heaters or accesories, etc... Although im making an exception next week to install the seat belts. I currently run the brakelighter strip in the rear window but truly feel the passenger light is needed though, at the very least for symetry. Im hoping to make a bracket this summer so I can mount it to where the bumper support attaches to the frame and have the light in the approximate symetric location. Its probably going to look like crap and i'll end up drilling it in the long run but worth a shot."
Bob, That's exactly where I'm at. Let me know(or post some pics) how it turns out. Good luck. Bruce |
03-11-2011, 02:33 PM | #19 | |
Mine is at the bottom of the rear window... I have toyed with the idea of having it at the top... just haven't tried it out yet. Frank |
03-11-2011, 02:37 PM | #20 |
My 31 Vic had only the tail\stop light on the left side as delivered from Ford. I could not bring myself to drill holes in the right rear fender for the installation of a light. For a number of years I had an accessory stop light attached to the bumper bracket on the right.
Recently I installed a better remedy. I made a bracket that attaches to the right bumper bracket, installed a mounting bracket from a 32 Ford, and a Model A lamp assembly with LED lights in it. It may drive the purests crazy, but it is functional and can always be removed. Photos attached, I hope. Tom Endy |
