Old 02-26-2022, 03:21 PM   #1
saxman657
Default Winfield Head
I recently purchased a rebuilt engine and it came with a Winfield 7:1 head and was hoping someone could help me identify if this is an original or a remake. Note the 1-12 above the Winfield name and the "PAT PEND" below the name. I'll be driving this on a B Diamond block with a Stipe 305 touring cam.
saxman657 is offline   Reply With Quote
Old 02-26-2022, 04:08 PM   #2
Jersey Mike
Jersey Mike's Avatar
Default Re: Winfield Head
From the shape of the combustion chamber you have a 6 to 1 head. Looks to be original if it’s cast iron. The 7 to 1 had a crows foot design combustion chamber.
Jersey Mike is offline   Reply With Quote
Old 02-26-2022, 07:12 PM   #3
Dodge
It definitely looks like an original head. I don't think its a 7:1 though.
You would have to CC the head to be positive. It could have been surfaced a time or
two in all the years. Are there any other stampings on the surfaced pad on the head?
Dodge is offline   Reply With Quote
Old 02-26-2022, 08:13 PM   #4
nkaminar
nkaminar's Avatar
It looks like a good combustion chamber design. I think you will be happy with its performance regardless of the compression ratio.
Old 02-27-2022, 02:40 AM   #5
saxman657
No other stampings, and unfortunately I can't make out any serial number on the pad below the PAT PEND stamping, but it really does sound like it is 6:1 or maybe slightly higher depending on what someone might have done to the surface. Looking forward to see how she performs.
Old 02-27-2022, 02:42 AM   #6
saxman657
Thanks for the input. I'm sure I'll be happy with it as well. I'll be using a Stipe touring cam with it on a B diamond block with Stipe oil pump so hopefully she'll be good on the open road
Old 02-27-2022, 12:05 PM   #7
Jim Brierley
The first number of the serial number indicates the compression ratio. Winfield used the crows foot on the 7:1, but not on all 7:'s. It looks like the plugs are 14mm??? Early Winfield's used 18mm. He made a few in aluminum, I think only for the Super Winfield's?
Jim Brierley is offline   Reply With Quote
Old 02-27-2022, 02:07 PM   #8
alexiskai
alexiskai's Avatar
These do look like 14mm, which would line up with other reports of the "1-__" series being 6:1 with 14mm. I saw a hi-res version of this photo and I'm 90% sure there's a serial number under the paint. Just gotta dig it out of there and you'll find the compression ratio.
Old 02-27-2022, 03:11 PM   #9
johnneilson
hmmm,
I have a crows foot here, original with 16mm plugs.
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 02-27-2022, 07:06 PM   #10
Bob C
WOW, my serial number is 9111. The number cast into the top left front
is 1-28, crows foot chamber with 18mm plugs.
Bob C is online now   Reply With Quote
Old 02-27-2022, 09:49 PM   #11
saxman657
I've looked closer and can see the faint inscription of a 6 in the serial number area, so I'm sure its a yellow head. Spark plug holes are 18mm with 14mm adapters so I assume this is an early yellow head?
Old 02-28-2022, 12:59 AM   #12
alexiskai
alexiskai's Avatar
If you want to convert back to the 18mm plugs, Winfield originally spec'ed those with the Champion 7 plug, which was used on mid-30s Ford V8s. The equivalent modern plug is the Champion D16. However, I've seen people report that they get better results on cast iron yellow heads with the D14. This is another place where JimB's opinion would be more informed than mine.
Old 02-28-2022, 01:08 AM   #13
saxman657
Is the gap the same? Recommended Spark plug for the 14mm and gap?
Old 02-28-2022, 12:49 PM   #14
Jim Brierley
I used D-14 with my yellow head.
Thread Tools
Display Modes
