Old 01-30-2022, 07:03 PM   #1
quickchange
quickchange's Avatar
Default Thermostat housing
Who sells, produces the top water outlet that takes a thermostat ? Can,t seem to find a listing with any of the main dealers, yet seen them forsale somewhere, Thanks Derek in a stinkin hot NZ feels like in Hawaii except no hula girls,
quickchange is offline   Reply With Quote
Old 01-30-2022, 07:18 PM   #2
motordr
Default Re: Thermostat housing
Vintage precision.com. They have this and also the hub puller. Ted vintageprecision.com
motordr is offline   Reply With Quote
Old 01-30-2022, 07:20 PM   #3
motordr
Vintage Precision is at vintageprecision.com I have their hub puller, it’s very well made. Ted
Old 01-30-2022, 11:14 PM   #4
Herb Concord Ca
I have their thermostat housing on both my Model A's. Best you can buy.
Herb Concord Ca is offline   Reply With Quote
Old 01-31-2022, 08:39 AM   #5
nkaminar
nkaminar's Avatar
One of the problems with the thermostat in the radiator hose is that it can move up the hose away from the outlet. That can be solved by adding a hose clamp to keep it in position. The other problem is that is does not sense the coolant temperature very well and will cycle open and closed during the summer. That can be helped by drilling out the hole in the flange to about 1/4 inch or in extreme cases adding more holes. The thermostat housing at the top of the head will help with both of these issues.
Old 01-31-2022, 08:40 AM   #6
Nosetime
Nosetime's Avatar
Vintage Precision is a work of art, very happy with mine.
Nosetime is offline   Reply With Quote
Old 01-31-2022, 09:54 AM   #7
Ernie Vitucci
I have it as well...Car runs cool and it almost looks factory...much better than just having a Thermostat in the upper hose...they also supply a much better than average Thermostat. Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 01-31-2022, 03:28 PM   #8
quickchange
Thanks guys will mail them & get some under way ,
Old 02-03-2022, 09:54 PM   #9
Chris Haynes
Chris Haynes's Avatar
I wish they made one to fit a Riley head.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 02-03-2022, 11:26 PM   #10
Synchro909
Synchro909's Avatar
Derek, I have one of those housings and had a problem getting fittings for it. Only a hydraulics place had NPT fittings. Every other application used BSPT. There is one thread per inch difference between them. I would expect NZ is the same Why oh why do they do that $#!T?
Old 02-03-2022, 11:31 PM   #11
johnneilson
I think it is just geographic location. Around here it is hard to find anything other than NPT.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 02-04-2022, 12:45 AM   #12
w.michael
w.michael's Avatar
How can it fit both the '28-'29 models and the '30-'31 models?
W. Michael
w.michael is offline   Reply With Quote
Old 02-04-2022, 07:58 AM   #13
updraught
updraught's Avatar
https://www.ralstoninst.com/news/sto...and-bspt-seals
So north America is different from every one else again...
updraught is offline   Reply With Quote
Old 02-04-2022, 08:55 AM   #14
nkaminar
nkaminar's Avatar
McMaster Carr has both types of fittings. They are easy to deal with and fast but expensive. The BSPT fittings use a gasket rather than sealer or Teflon tape.
Old 02-04-2022, 10:34 AM   #15
johnneilson
Not quite, BSPP connection uses gaskets
BSPT is a tapered thread connection
J
Old 02-04-2022, 10:36 AM   #16
johnneilson
Probably so, but our equipment doesn't leak...
All good! John
Old 02-04-2022, 10:59 AM   #17
Y-Blockhead
Y-Blockhead's Avatar
Well, you are using American made items...
Old 02-04-2022, 11:01 AM   #18
katy
katy's Avatar
I'm surprised that Australia doesn't use metric pipe threads.
https://trimantec.com/blogs/t/thread...fication-guide
Old 02-04-2022, 04:00 PM   #19
31steve
Chris, They make one for a Miller head that I think would work .
File Type: jpg thumbnail_Miller-Head-Thermostat-Housing-2.jpg (101.5 KB, 72 views)
31steve is offline   Reply With Quote
Old 02-04-2022, 05:07 PM   #20
Synchro909
Synchro909's Avatar
So am I. It seems some industries haven't caught up. That said, it is obvious that all of the systems work in a similar way and work just fine. It is when we try mixing them that the troubles start. IMO, we should dump BSPT and NPT and all go metric as a world wide standard. I'm not holding my breath on that though.
