09-23-2016, 06:10 PM | #1 |
'33 pickup accelerator pedal ?????
My '33 pickup has a ball on the interior shank for another linkage hook-up. Was this leftover from '32 vehicles or is there supposed to be another linkage that connects up inside the cab to the hand throttle lever thru the dash ????
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
09-23-2016, 06:23 PM | #2 |
Re: '33 pickup accelerator pedal ?????
I assume that the truck is the same as the '32 passenger/truck (that is probably dangerous). I think the knob to the left side of the instrument cluster was attached to a rod that went to a bell crank and which then went to the pedal. What is in that hole, does it look like there was any bell crank on the tunnel?
Charlie Stephens |
09-23-2016, 06:35 PM | #3 |
sorry image got twisted...see the ball linkage at the upper end of the shaft .....
09-23-2016, 11:37 PM | #4 | |
Charlie Stephens |
09-24-2016, 12:02 AM | #5 |
Don't believe 33 V8 commercial had a bellcrank.The bellcrank was afixed on the dash tunnel of the 32's.33 V8 commercial had full length choke and throttle rods.Your pedal probably was a carry over from 32.
09-24-2016, 04:26 AM | #6 |
09-24-2016, 12:04 PM | #7 |
Yes that clears it up, mine was a 4 cylinder and later converted to V8 engine.
