Old 08-16-2021, 01:25 PM   #21
Tim Ayers
Default Re: 81A Big A Heads
Originally Posted by Bored&Stroked View Post
There is also a very rare 81AS head - which a friend of mine from Finland has a set of. They are a special high-compression design - and look just about the same as most of our aftermarket chambers (like Edelbrock, Navarro, etc).
I'd love to find a set of these . . . well, just because . . .
Attachment 470705
Me too!
Old 08-17-2021, 06:59 AM   #22
Step-down
Step-down's Avatar
B&S
Keep reading your last post , find it very interesting and open up interesting history of out Flatmotors
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 08-17-2021, 07:11 PM   #23
Bored&Stroked
Bored&Stroked's Avatar
Originally Posted by Step-down View Post
B&S
One thing us 'Flathead Guys' have learned over the years is that having a consistent .040 or so squish over the piston is key for turbulence and overall performance. It doesn't matter if it is a Harley KR, a Cadillac or a Ford flathead . . . same deal with all of them.
Old 08-17-2021, 08:11 PM   #24
Kube
Kube's Avatar
[QUOTE=Bored&Stroked;2046702]There is also a very rare 81AS head - which a friend of mine from Finland has a set of. They are a special high-compression design - and look just about the same as most of our aftermarket chambers (like Edelbrock, Navarro, etc).
Yeah, good luck in your search!
I had found a pair at Hershey many years ago. NOS and aluminum to top it off. That (aluminum) made them even more rare. Paid an insane price for them but needed them for a at that time future restoration of a very rare '40 Ford Convertible Coupe.
Old 08-19-2021, 09:11 PM   #25
Phil Gillespie
Phil Gillespie's Avatar
[QUOTE=Kube;2047163]
On that picture of the engine where is the radiator cooling fan located?
Thanks,
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 08-19-2021, 10:11 PM   #26
cadillac512
cadillac512's Avatar
Hi Phil
On that '40 the fan with short extension will be mounted directly to the end of the crankshaft. If you look very closely I believe the tip of a blade can be seen near the distributor.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-20-2021, 06:06 AM   #27
Bored&Stroked
Thanks Kube: I must ask, why those particular heads for that car - was it because they were aluminum? There were quite a few other 81A heads that would have been correct on that engine. Just wondering - given that you had to pay a lot for them???
Did you notice the deeper domes as well?
Old 08-20-2021, 11:46 AM   #28
Phil Gillespie
Originally Posted by cadillac512 View Post
Hi Phil
Terry
Terry thanks for that info much appreciated
Phil NZ
