10-25-2020, 08:27 AM | #1 |
Source for epoxy-filled 6 volt coil ?
None of the parts suppliers selling replacement 6 volt coils provide any detail or specify whether oil of epoxy filled.
What is considered to be the best replacement 6 v coil available ? Thanks - Jim |
10-25-2020, 08:45 AM | #2 |
Re: Source for epoxy-filled 6 volt coil ?
Try FS Ignitions, may be able to help. I am running their ignition system.
Bob |
10-25-2020, 09:25 AM | #3 |
Pertronix offers both one point five and three OHM coils in either epoxy or oil filled versions .. The one point five OHM coil works with a six volt system . The three OHM version is for twelve volt systems . This is a performance coil that looks exactly like other replacement coils . You get instant starts and power that a person can feel . If the extra power frightens a person , they won't have to press the accelerator pedal quiet as far . I use these coils on all of my model A's The Pertronix coil was the best forty dollars that I have ever spent for a performance part .
10-25-2020, 09:32 AM | #4 |
Pertronic 40111 1.5 ohms epoxy filled is what I am using. No issues over five years.
https://www.summitracing.com/search/...ronics%2040111 |
10-25-2020, 04:58 PM | #5 |
I took Purdy's advice and got a Petronix epoxy filled coil, the "Flame Thrower." Let me just say, as usual, Purdy knoweth of what he speaketh.
10-25-2020, 05:31 PM | #6 |
10-25-2020, 07:04 PM | #7 |
10-25-2020, 08:41 PM | #8 |
Thanks Bob-A !!!
10-25-2020, 09:06 PM | #9 | |
10-25-2020, 10:10 PM | #10 | |
10-26-2020, 10:04 AM | #11 |
Something else is more than likely wrong .
10-26-2020, 04:05 PM | #12 |
But what else could be wrong?? The car is 12 volt as was the coil. With no changes to anything, the replacement coil is still going fine after 7 years. The pertronic one lasted a few months.
10-26-2020, 04:16 PM | #13 |
Thanks for all the comments. I’m going to try the 6V Pertronic epoxy-filled coil, but will carry the original 90-year old coil as a back up.....or should I do it the other way around??
Jim |
10-26-2020, 06:16 PM | #14 | |
Got nothing to lose |
10-27-2020, 06:20 AM | #15 |
Anything can fail at any time. Coils included.
I just went thru something similar with condensers. 5 bad ones which some said couldn't happen. The 'burn-proof' maker must have had a bad batch. |
10-27-2020, 09:20 AM | #16 |
I have had excellent results for fourteen years with the Pertronix coils . There can be duds with any part that is offered . .
10-28-2020, 08:25 PM | #17 | |
I like it so much I got one for my '51 CJ-3a.....it too runs great... Keep the old coil as a spare that you know will work if needed. Randy... .
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
10-29-2020, 06:00 AM | #18 |
Seems like everyone is on the hunt for something that didn't even exist for a useful purpose until the 1940's (epoxy). How did people get by for the previous 12 years, if a 90 year old coil is good enough for a spare - doesn't make sense.
John |
10-29-2020, 06:34 AM | #19 |
Doesn't make sense ? Why doesn't it ?
Oil coils don't like to be tipped upside down [ neither do I ] and tar coils aren't made anymore. Epoxy is just a modern substitute. |
10-29-2020, 09:09 AM | #20 |
Nailed it! |
Thread Tools | |
Display Modes | |
