10-22-2020, 01:06 PM | #1 |
Bullet connector crimping tool
The bullet connectors on my 38 have four (opposing) crimps per below photo; the Lucas style crimping tool I have simply mashes the connector.
What is the correct tool to achieve the original style crimp ? Thank you
No job’s done ‘til it’s all done Last edited by Jacques1960; 12-04-2020 at 01:54 PM. |
10-22-2020, 01:45 PM | #2 |
Re: Bullet connector crimping tool
I don't have a picture, have the tool, pliers with hole, as squeeze 4 pins crimp, has end cap to position connecter
10-22-2020, 01:50 PM | #3 |
There is a pliers type tool that you put the bullet connector
in, squeeze the handles and a bunch of little pins come in and squeeze the recessed part of the bullet. G.M.
www.fordcollector.com |
10-22-2020, 01:55 PM | #4 |
Or you could solder them to the wire(s).
Paul in CT |
10-22-2020, 01:56 PM | #5 |
i solder them much. better than a crimp
10-22-2020, 03:07 PM | #6 |
Some suppliers only supply machined bullets that will not crimp but fracture and should only be soldered. Did a little massaging on one of my tools and it worked for me. The trick is not to over crimp.
10-22-2020, 04:11 PM | #7 |
Interesting - I have an old Radio Shack crimper now begging for a date with the Dremel !
No job’s done ‘til it’s all done |
10-22-2020, 05:22 PM | #8 |
Also, as an experiment, I’m going to borrow a Triumph / Norton hexagonal crimper and see how (if) this works on Dennis Carpenter brass bullet connectors
10-22-2020, 06:21 PM | #9 |
I soldered all mine - that's my vote very easy
10-24-2020, 08:07 AM | #10 |
CW Moss has the (hopefully softer) white metal bullet connectors in their Model A catalogue; the hard brass ones from Carpenter and RI Wiring both seem to be solder only propositions due to hardness. Will update once new tool arrives and will try on both “hard” and “soft” connectors
10-24-2020, 02:40 PM | #11 | |
10-26-2020, 10:23 AM | #12 |
Eureka ! The Bonneville Shop, which specializes in Brit bikes like Triumph and Norton, just delivered a ratcheting hexagonal bullet crimper capable of forming perfect crimps on both hardened and white metal bullet connectors. Between this and a dab of solder, the connections on my 38 should be good for another 80+ years
10-26-2020, 10:28 AM | #13 |
Photo included: Lucas style on top (worthless POS), Bonneville Shop below
10-26-2020, 10:36 AM | #14 |
Nice. That's a pricey little tool at $95 though.
10-26-2020, 11:00 AM | #15 |
It is, but you know how it can be with purpose-built tools
10-26-2020, 01:19 PM | #16 |
Here's the crimper I have--- 4 pins crimp at same time
10-26-2020, 01:36 PM | #17 |
10-26-2020, 02:55 PM | #18 |
10-26-2020, 03:13 PM | #19 |
Spot on, and a great price
10-26-2020, 03:52 PM | #20 |
I have a bunch of Daniels crimpers for aircraft use that are 4-way. The large size is less common but they are out there.
