10-19-2020, 02:49 PM | #1 |
1940 Ford Convertible Top Frame shoulder bolts
Does anyone have a source for the 1940 convertible top frame shoulder bolts? I especially need to find the two smaller ones that attach the rear steel bow to each side of the top frame. The shoulder diameter is 3/8”. Thread size is 5/16-18. About an inch long or so. See pic.
10-19-2020, 05:43 PM | #2 |
Re: 1940 Ford Convertible Top Frame shoulder bolts
If you can't find them, you could make some by turning down a 3/8 dia. stainless bolt on a lathe and then cut new threads. I have had success doing that.
10-19-2020, 06:08 PM | #3 |
Totally Stainless should have what you need. They make convertible top bolts along with many other products including various kits. Excellent quality.
http://www.totallystainless.com/ |
10-19-2020, 08:20 PM | #4 |
Thank you for all the replies. Much appreciated!
10-19-2020, 09:53 PM | #5 |
I might have an original, I will look. I used to have a 40 Convertible. Will PM you if I do.
10-20-2020, 07:08 AM | #6 |
10-20-2020, 11:38 AM | #7 |
I had to have the top iron bolts made for my '39 conv. Originally they were chrome plated, the replacements I found did not have the correct shoulders and the heads were small. I had a machine shop make the bolts out of stainless steel then I polished the heads.
Bill.... 36 5 win cpe |
10-20-2020, 12:40 PM | #8 |
Here are scans from an original 1940 parts book showing the various shouldered bolts used on 1940 Ford (model 66) and Mercury convertible (model 76) and convertible sedan (model 74).
I would be careful with Totally Stainless, While their quality is superb their interchange is suspect as their catalog lists 1939-40 convertible... the two years are different. Compare the specs of what you need to what you have. |
10-20-2020, 06:10 PM | #9 |
Thank you for the advice. Tried to reply earlier and describe an alternate approach that I took. Bought two chrome bolts and a 3/8 OD steel fuel line, which is 5/16 ID. I cut 1/2” lengths of the tube which acted as sleeves or shoulders for the bolts. Worked perfectly.
10-20-2020, 08:52 PM | #10 |
I do have some original bolts, could be re-chromed. PM me your email address.
