Old 09-04-2020, 07:44 AM   #1
42Ford M-H
42Ford M-H's Avatar
Default Airtex E8902
Recently picked up a 8902 from RockAuto, looks like an Airtex... Has a generic 8902 printed on the side of it. It is not flow thru, I can barely blow any air thru the pump in either direction. Maybe something change on the manufacturing side?
Anyone else run into this yet?
From what i can tell this is not a Carter, it looks like the Airtex that others have posted in other posts.
So now im back to looking for a 6 volt fuel pump to use for priming that allows free flow.
Any recommendations? or where i can get my hands on e8902 that still has flow thru?
42Ford M-H is offline   Reply With Quote
Old 09-04-2020, 08:00 AM   #2
42Ford M-H
42Ford M-H's Avatar
Default Re: Airtex E8902
Well... answered my own question. Airtex was bought by someone else and the internals of the pump are different now. Sounds like at some point they want to switch back. He didnt sound like thats going to happen for awhile, if ever.
Old 09-04-2020, 08:04 AM   #3
KGS
KGS's Avatar
Here's a "work around" that will enable you to use
that pump. I think I picked this up off the "Barn" a
few years ago, but I don't know who posted it. It's
fairly self explanatory.
Ken
Use the search function here on the "Barn". There are
a number of posts describing how to bypass the electric
pump so the manual pump will function.
Here's a link to one that should help.
https://www.fordbarn.com/forum/showt...el+pump+bypass
EDIT: picture didn't attach. I'll retry in a bit
KGS is offline   Reply With Quote
