Old 08-30-2020, 11:25 PM   #1
Talkwrench
Talkwrench's Avatar
Default Again?! this time juddering at a stop
Its been months since replacing the center bearing and all has been fine, but just lately and only every now and then I get a juddering[?] just before the car stops.. WTF?! Anyway I cant pin point what it is. Ive looked down as its happening and my vacuum gauge is rock steady, Ive coasted, nothing, foot has been on the brake , nothing, I cant hear anything ..? I thought it might be a brake shoe dragging but I can pull away no problem, All seems normal when running, only just in that last two - three seconds before it stops.. The only thing Ive done recently is swapped to radial tyres [ 15x6 F100 rims]
Ideas guys?
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 08-31-2020, 12:04 AM   #2
Brian
Brian's Avatar
Default Re: Again?! this time juddering at a stop
out of round brake drum?
Unfortunately, two half wits don't make a whole wit!
Brian is online now   Reply With Quote
Old 08-31-2020, 01:32 AM   #3
Tinker
Tinker's Avatar
At idle and a great vacuum, it might be in your "head". But whom knows. Maybe the front end is loose or... all guesses. How is your kingpins to steering.
Old 08-31-2020, 01:54 AM   #4
Talkwrench
Talkwrench's Avatar
I think I would feel that throughout all the braking..? The juddering when I can feel it can be non existent to quite bad ..
Kingpins do have ware but not bad.. it wouldn't cause that type of juddering though, and why sometimes and not all the time?
Old 08-31-2020, 02:00 AM   #5
Tinker
Tinker's Avatar
Whom knows... But not engine though right?
Old 08-31-2020, 02:14 AM   #6
Phil Gillespie
Phil Gillespie's Avatar
Long shot, check all wheel nuts are tight since wheels have recently been off.
Fault Finding 101; First look at what you have recently played with.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 08-31-2020, 09:18 AM   #7
54vicky
54vicky's Avatar
not being smart never heard the expression juddering is it an aussie expression.I take it to mean shuddering but wondering is all
54vicky is offline   Reply With Quote
Old 08-31-2020, 09:19 AM   #8
19Fordy
19Fordy's Avatar
Did you install an aftermarket center bearing or NOS? Think back very carefully and try to recall exactly what you did on the installation.
Are all the nuts and bolts tight?
Are transmission and motor mounts tight?
Do you have "anti chatter rods?"
Does it happen "just before the car stops" with your foot on the brake pedal?
Does it happen when rear wheels are off the ground when on jack stands?
The loose wheel nut theory sounds very possible. Check that first.
Check the tightness of all the nuts and bolts you removed to replace the center bearing, if possible.
Pull rear drums and check wheel bearings etc.
Are all the rear radius rod nuts and bolts tight?
Old 08-31-2020, 10:36 AM   #9
Als48
How about the clutch? Have you had problems with it engaging smoothly. I guess it's possible that it is not releasing smoothly. Reverse of when it shudders upon engagement. Never heard of it though, even tho I have had clutches stick, but usually after sitting.
Al Hook
Als48 is offline   Reply With Quote
Old 08-31-2020, 11:25 AM   #10
solidaxle
solidaxle's Avatar
Fault Finding 109; First look at what you have recently played with.
Phil NZ
Along with the lugs, maybe a bent wheel?
solidaxle is offline   Reply With Quote
Old 08-31-2020, 01:09 PM   #11
flatford8
flatford8's Avatar
Oil or grease on a brake shoe?.....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 08-31-2020, 03:02 PM   #12
Lawson Cox
Lawson Cox's Avatar
Grimlins.
Old 08-31-2020, 03:20 PM   #13
Aarongriffey
Mechanical brakes? Hydraulic?
Car? Truck? Motor bike? Push scooter? Farm tractor??.
IF they’re mechanical try disconnecting the pull rod or cable from one wheel at time and trying it.
Can you stop the vehicle with the hand brake. Feel anything?
Wear in the king pins usually doesn’t cause a shudder or a judder.
Aarongriffey is offline   Reply With Quote
Old 08-31-2020, 07:04 PM   #14
Talkwrench
Talkwrench's Avatar
Shuddering will do [B]
35 pickup . Juice brakes
clutch operates as per normal was all apart about two years ago
wheels are straight I spun them up before I fitted the tyres
feels like the engine stalling and shuddering, however the vacuum gauge doesn't move , Alt light doesn't come on etc .
the center bearing is NOS was a prick to get in. I did had to tap the torque tube when putting it back together, didnt quite slide over the shaft. I did check after and all spun freely .. I know that shouldn't of happened at all ..
Are all the nuts and bolts tight? yes
Are transmission and motor mounts tight? yes
Do you have "anti chatter rods?" yes .. they where loose
Does it happen "just before the car stops" with your foot on the brake pedal? yes [and not heavy ]
Does it happen when rear wheels are off the ground when on jack stands? dont know
The loose wheel nut theory sounds very possible. Check that first. I torque them so ok
Check the tightness of all the nuts and bolts you removed to replace the center bearing, if possible. I'll check but have no doubts they're good
Pull rear drums and check wheel bearings etc. Jacked up rear and Ive got a random clicking - tick noise when turning both wheels.. aghh so that something, if it gets louder and more constant it will be similar to the center bearing gone again
Are all the rear radius rod nuts and bolts tight? yes
I went for a short trip after tightening the steady rods and it didn't do it , however its random and may take a longer trip..
Old 08-31-2020, 07:08 PM   #15
Talkwrench
Talkwrench's Avatar
Originally Posted by Lawson Cox View Post
Grimlins.
Well Lawson it is 2020, god knows it hasn't been good and anything is possible. I have not been anywhere near water , mmm one of my dogs is called Gizmo...
Old 09-01-2020, 09:12 AM   #16
solidaxle
solidaxle's Avatar
"feels like the engine stalling and shuddering, however the vacuum gauge doesn't move , Alt light doesn't come on etc ."
You need to distinguish if it's the motor or something else and go from there.
Are you loosing RPMS ?
Old 09-01-2020, 09:37 AM   #17
51woodie
51woodie's Avatar
My '46 Coupe has done the same "juddering" on rare occasions. It happened when I was moving ahead slowly on a slight incline, while feathering the clutch. Again, it rarely happens, but it sure shakes the car and attracts attention to anyone around. It stops when I completely disengage the clutch. I don't have anti chatter rods, motor mounts are new and tight, and the clutch operates smoothly with the correct travel and adjustment. As it is a rare occasion, I'm not too worried about it.
Juddering = Jerking + Shuddering
51woodie is offline   Reply With Quote
Old 09-01-2020, 10:54 AM   #18
deuce_roadster
deuce_roadster's Avatar
My vote is something due to the clutch or clutch linkage. It sounds like what happens when you don't push in the clutch as you come to a stop. Like after driving an automatic and forgetting you are in a stick vehicle.
Old 09-01-2020, 12:39 PM   #19
19Fordy
19Fordy's Avatar
This may be way off track but I had a similar situtation with a 1992 vehicle when I applied the brakes.
Turned out one of the new rear brake drums was out of balance. New drum installed and
problem went away.
Old 09-01-2020, 05:23 PM   #20
Lawrie
Lawrie's Avatar
Rob, my 28 ccpu had a huge shudder when cold coming down our drive,sometimes I thought it would snap a stub axle or something, I put up with it for a month or so, as it was right when I next applied the brakes, stripped the front brakes and it had grease on the linings,cleaned it with brake clean and it’s now as right as.
Lawrie
Lawrie is offline   Reply With Quote
