08-09-2020, 09:53 AM | #1 |
wiryjoe replacement wiring harness
Looking thru my parts stash, i find a couple of wiryjoe wiring harness. Never heard much about them. They look fine compared to others. Just wondered if anyone has used them and if they are as good as others. Thanks Ron
08-09-2020, 10:16 AM | #2 |
Re: wiryjoe replacement wiring harness
They were a good replacement back in the day and if the insulation doesn't crack when flexed, they would be fine. I know of several cars that are running the WireyJoe harnesses that were installed years ago. I personally use Chris Olson in Bend for new wiring.
08-09-2020, 01:02 PM | #3 |
The harness i removed from my 35 was a Wiry joe. It was not correct as compared to the BAUER which was patterned from a Ford original per Chris Olsen.
Although it was functionally correct.
Tim Downtown, Ca |
08-09-2020, 01:43 PM | #4 |
