Old 07-24-2020, 05:39 PM   #41
KiWinUS
KiWinUS's Avatar
Default Re: Let's build a drag race 8BA engine
What balancer do you now use Pete?
Old 07-24-2020, 05:48 PM   #42
tubman
tubman's Avatar
Originally Posted by flatheadmurre View Post
The only thing that is certain about bobweight calculation is that there is no consensus among engine builders regarding the benefits of over- or underbalancing a crankshaft...you ask 10 and you get a dozen different answers...
As I said, it looks like "flatheadmurre" is right again.
Old 07-24-2020, 05:49 PM   #43
Pete
Pete's Avatar
We have an old Stewart Warner. Have to lift the crank by hand or hoist over to the drill stand. Good upper body exercise.
Old 07-24-2020, 05:52 PM   #44
Pete
Pete's Avatar
He may be right but his math is off a couple.......giggle
Old 07-24-2020, 05:52 PM   #45
KiWinUS
KiWinUS's Avatar
Thanks Pete
I use. Sunnen.
Old 07-24-2020, 05:52 PM   #46
GOSFAST
GOSFAST's Avatar
"GOSFAST" uses 52% and you use 55% and agree with him? Looks like "flatheadmurre" is right again.
Not exactly, on 98% of our builds we use the conventional 50% bobweight formula, the others (all track-only) get anywhere from 52% thru 56%. We have dynoed literally "thousands" of motors (over a 40 year span) and refer back to the dyno sheets for the best results, including the bobweight numbers!
Thanks, Gary in N.Y.
P.S. Being a Flathead is definitely not going to be running at 7000/8000 RPM on the build were talking here I would use the 52% number! I would definitely also do something (like our girdle) to help keep it all together, at least on that "weak" center main area of the block (see the photo below)! I would also add, if Ford didn't "hang" the 2 large center counterweights on each side of the center main on the later units they would never have been able to keep that main brg from disintegrating. The Chevy race cranks have this same setup! Without those counterweights on 4.750" stroke Chev the mains will never survive, been there, tried it!
GOSFAST is offline   Reply With Quote
Old 07-24-2020, 06:24 PM   #47
Pete
Pete's Avatar
"Being a Flathead is definitely not going to be running at 7000/8000 RPM".
This part of your statement is totally wrong. An all out vintage circle track engine will have the hp peak in the 6500 to 7000 range and will be run 10 to 12 % over that at lift point on the track. That equates to somewhere over 7000 twice a lap. (assuming you are not in traffic)
Old 07-24-2020, 10:26 PM   #48
Ol' Ron
Ol' Ron's Avatar
It's harsd to imagine getting that much air into a flathead, to mak power at 6 or 7000 rpm. I have allot to learn, But at 87 I sometimes forgrt my name. Now with a Blower, or alittle smack, that;s a different story.
Gramps
Old 07-24-2020, 11:13 PM   #49
Tim Ayers
I know he's busy getting ready to head out west to Bonneville, but I'd really like Ronnie Roadster to jump in on the bearing cap support part of the this discussion.
I don't want to misquote him, but I think I recall him saying he only uses a strap support on that he designed on the center cap only on all but the Ardun full race motors.
I be interested to see Gary's 4 bolt set up, but I'm struggling to see how it doesn't compromise the pan rail/center web.
Old 07-25-2020, 06:13 PM   #50
Fordestes
Speaking of main support anyone here use the Flatattack support plate with the billet main caps? is that system good, bad, better than nothing ?
Fordestes is offline   Reply With Quote
Old 07-25-2020, 06:20 PM   #51
Ronnieroadster
Ronnieroadster's Avatar
Hi Tim OK heres one of my simple secret improvements to add strength to our beloved flathead blocks.
Let me explain what I have learned running our flatheads full out not only for records at Bonneville but also for our many dyno pulls. Theres absolutely no need for the massive girdles I have seen many use however if thats what you want to use go for it but it is waste of money,time and weight.
On all of my record setting flathead blocks to add support to the center main bearing cap I simply place a flat steel support the width of the cap and one inch in height on top of the steel center bearing cap this support is bolted to the cap with 5/16 hardware which is only used to locate this support.
The steel support is long so it touches the inside surface of the oil pan. Now heres where the support is made to the center of the block. On the outside of the oil pan theres a steel plate that touches the outside of the pan wall and also has a flat surface sitting on top of the oil pan covering three oil pan bolt holes. This L shaped plate is held in place by the three oil pan bolts on each side of the oil pan.
Now for the additional strength I add a 7/16 cross bolt that now goes threw the steel outer plate and the oil pan side wall and finally threads into the side of the inner steel center main bearing cap support. This assembly adds a huge amount of central support to the block. Think how much effort it will take to move such a structure.
I can tell you we have tested out our design not something I wanted to do but going for records has had its ups and downs. Here goes on the backup run for the record at the 2 1/2 mile marker we experienced a huge internal failure due to oiling issues the two rear connecting rods which were steel Cunningham rods broke after the bearings seized on the rod journal.
The now broken rods number 4 and 8 began chain sawing the inside of the block the steel cam was broken into many pieces between the center and rear cam bearings. With the cam broken the lifters now joined the cam parts hitting the spinning crankshaft slamming into everything possible.
With that much internal carnage the center main bearing area of the block remained completely intact. The crankshaft survived with a slight run-out in the center when I checked it between centers. I will add on more detail all of the internals in this and all my engines are USA products no off shore stuff EVER.
Oh I forgot to add even with this complete disaster on the return run the car coasted across the line over 170 MPH we bumped the record by 20 MPH at that point we now had two records. Now years latter we have set four more records with our flathead engines each one using this simple center main support design.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 07-25-2020, 07:56 PM   #52
KiWinUS
KiWinUS's Avatar
Ronnie thanks for great explanation & sharing you wealth of knowledge.
Cheers
Tony
Old 07-27-2020, 12:52 PM   #53
HopRod
Ronnieroadster
Ronnie, so if I understand your design correctly, does tightening the oil pan bolts, via the L shaped bracket, increase preload on the main cap?
HopRod is offline   Reply With Quote
Old 07-27-2020, 02:13 PM   #54
Ronnieroadster
The oil pan bolts only hold the L shaped support tightly to the oil pan rail surface. Once the bolts are tightened I now drill the cross bolt hole now going threw the L bracket and into the side of the oil pan and finally into the side of the steel support. I use a center drill for this operation. The idea is to get a centered hole location into the side of the main bearing cap support so every time things come apart and go back together the support locates exactly as the first time. Once i have that centered location I now remove the steel support thats on the main bearing cap and finish drilling the needed tap size hole for the 7/16 bolt using the drill press. To keep things accurate every time I do not use an oil pan gasket. I seal the pan to the block using a good quality silicone sealer.
Ronnieroadster
Old 07-27-2020, 05:40 PM   #55
Lawrie
Lawrie's Avatar
Ronnie, you got any pics of that setup?
Lawrie
Lawrie is offline   Reply With Quote
Old 07-27-2020, 05:59 PM   #56
Yoyodyne
Yoyodyne's Avatar
Very clever setup, I wouldn't have thought of going through the pan with fasteners.
Do you modify the main cap for a seat for the bar, or just have it bear on the spotface areas for the main bolts? Where are the 5/16 bolts located and how are they used?
I'll never do this to a flathead, but I might be able to apply it elsewhere.
Thanks for the description!
Yoyodyne is offline   Reply With Quote
Old 07-27-2020, 08:09 PM   #57
Tim Ayers
This is not to sound like a fan boy, but more so as someone who admires mechanical ingenuity and the ability to problem solve. We are fortunate to have a bunch of these guys on this forum who are willing to share their knowledge and experience freely.
Going to Ron's shop and seeing some of his tricks and modifications he does to these engines is truly inspiring.
Standing next to his race car as it starts up and feeling the exhaust literally punch you in the chest is impressive to say the least. Then you hear the sound of the motor...
I feel very fortunate to have gotten to know Ron and his family. When he gives me advice, I listen.
Old 07-27-2020, 10:05 PM   #58
Pete
Pete's Avatar
Originally Posted by Tim Ayers View Post
This is not to sound like fan boy, but more so as someone who admires mechanical ingenuity and the ability to problem solve. We are fortunate to have a bunch of these guys on this forum who are willing to share their knowledge and experience freely.
Well, I feel the same way. Ron, JWL, I and others have shared much info by email over the years. I have learned many things from them and I hope I have been of help also. I hope to meet them in person some day.
Vintage racing has been very good to me over the years. Much more so than the pro racing that gave me most of what I know.
One of the most important things I tell vintage RACING engine builders is, follow what the TOP current day pros in ANY racing venue are doing to their engines. Then if it looks like that procedure may help a vintage engine, modify it so as to apply and try it.
Old 07-29-2020, 02:32 AM   #59
frnkeore
frnkeore's Avatar
Is there a cubic limitation in H/Gas? Or a cubic inch to weight rule?
As a basic thing with a N/A, FH, you need as much compress, as you can possibly get.
Make sure you know the compressed thickness of you head gasket, then order your pistons to get .038 +/- .002., piston to head clearance.
The stock deck height is 10.437 +/- .005. To order pistons, you'll have to know that and the depth of the dome in the head, to get things right. The dome varies, in different heads, as you know.
You can use the Ol' Ron method to measure the dome clearance, by wading some tin foil and turning the engine over.
It takes a lot of actual measuring to get max compression out of these engines.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 07-29-2020, 02:41 AM   #60
frnkeore
frnkeore's Avatar
Added:
I don't know how after market piston manufacturer's measure CH (I'm to cheap to order a set) but, Ford measures to the corner of the dome, above the top ring, not to the top of the dome. That corner, also has to be more than .036 from the head surface so, make sure you know what that measurement is. Std CH is 1.530, as I remember.
Frank
'35 Ford Model 51
'48 Ford F3
