03-11-2020, 05:38 AM | #1 |
Bucket seats
Hi, I'm working on this 65 falcon Futura. I have installed a hurst floor shift. I can't keep the front bench seat. So I purchased two 65 mustang bucket seats with poor upholstery. Has anyone purchased upholstery, say from tmi distributors? How did the the stuff work? Also I would consider buying seats that don't match if they were in descent condition. Wich also leads me to ask if anyone knows of a good source. Thanks
03-11-2020, 12:27 PM | #2 |
Re: Bucket seats
I have no idea of the quality. Maybe someone on a Mustang forum could give some insight. You may need the foam pads too. Hog ring pliers & rings will be needed to install the covers. I can sew my own stuff but the prices are hard to beat on assembly line produced stuff. If it's half way decent then you won't lose much if it isn't. Use it till it rips & buy some better stuff.
03-11-2020, 07:34 PM | #3 |
Re: Bucket seats
Gino - I suggest National Parts Depot (NPD): they handle repro seat covers for all Mustangs. You can purchase just the fronts, and I found them very reasonable (and the fit was perfect). They also sell the hog ring pliers and related hardware: I cheated, took the easy way out and had a local upholstery guy do the work; however, because it was so easy, the price was surprising inexpensive. (Don't have an idea about your area costs.)
WARM REGARDS, MARCUS |
03-11-2020, 08:16 PM | #4 |
Re: Bucket seats
Back in HS I put a T-10 and Hurst shifter in my '65 Falcon 2 dr. wagon with a bench seat. If you are talking about a T-10 you just need a different tail shaft which will move the Hurst shifter forward to clear the bench seat. Don't know about a top loader.
Making the simple complicated for over 30 years. |
03-11-2020, 08:18 PM | #5 |
Re: Bucket seats
I think you're also going to find that the Mustang seats are going to put your rear on the floor unless you build seat risers to make up the height. Been there, done that.
03-13-2020, 01:28 PM | #6 | |
Re: Bucket seats
Years ago, a friend of mine put '66 Mustang front bucket seats into his '64 Falcon Ranchero, and don't remember any difference in height from his bench seat... .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
03-13-2020, 03:10 PM | #7 |
Re: Bucket seats
That's my recollection as well.
03-15-2020, 07:32 AM | #8 |
Re: Bucket seats
Yup, put mid 80s Mustang seats in a 66 Falcon Ranchero. Was almost a direct bolt in. Seat height was same as the bench.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
03-18-2020, 11:10 PM | #9 |
Re: Bucket seats
Early Mustang seats are about 3" lower than the Falcon seats. Years ago a buddy did the swap and used some 2X4's for spacers. looked ugly, but did the job. Why won't the bench seat work, do you have something other than a Falcon trans., or was the floor shifter conversion for something other than a Falcon?. I've done this in the past on a virgin '65 Falcon and the bench seat cleared with room to spare. Sounds like you are using a Mustang trans., the shifter attaches to the end of the tail housing while a Falcon, Fairlane and Galaxie are at the front of the tail housing
03-19-2020, 11:34 AM | #10 |
Re: Bucket seats
Post a couple of pictures so we can be of better service. I like the bench seats myself, but Mustang buckets are nice too. You can practically build an entire Mustang out of what is now available.
I have a bench seat in my car and had to massage the Hurst handle to get it off the seat in 2nd and 4th gear. Bent it cold in a large bench vise. |
