Old 08-26-2019, 04:59 PM   #1
Tod
Default B head sample.
This is the first B head at my new iron foundry. The last foundry didn't have quality control so they had to go. Winfields, Thomas, and blocks are all slated to be cast.
Tod
Tod is offline   Reply With Quote
Old 08-26-2019, 05:20 PM   #2
KUDZUVIPER
Default Re: B head sample.
Looking good Tod. What will be the standard compression ratio? will spark plugs be tapped/sizes? and finally, cost?
KUDZUVIPER is offline   Reply With Quote
Old 08-26-2019, 09:20 PM   #3
Dodge
Tod, excellent. Looks like you really nailed the crows foot combustion chamber.
Dodge is offline   Reply With Quote
Old 08-27-2019, 02:18 AM   #4
lsr490
Very nice
lsr490 is offline   Reply With Quote
Old 08-30-2019, 12:40 PM   #5
Tod
I picked this head up from the foundry today. It is very nice, especially for the first sample. They mentioned being very interested in sampling an engine block asap. I have quite a few Winfield heads and iron Thomas heads to make as well.
Tod
Old 08-30-2019, 06:23 PM   #6
Beater
Beater's Avatar
as you have seen on FB, im in for one this winter
Beater is offline   Reply With Quote
Old 09-02-2019, 11:37 AM   #7
Beater
Beater's Avatar
got lucky on the bottom to
Old 09-05-2019, 11:02 PM   #8
noyo55
I’m also ready when you get into production. I see that you cast. ‘C” into it. Since it’s higher compression might be more appropriate if it was “C+” ?h
noyo55 is offline   Reply With Quote
Old 09-05-2019, 11:32 PM   #9
Charlie Stephens
Since I would like it to look stock under the hood I would prefer just the "C".
Charlie Stephens
Old 09-06-2019, 11:09 AM   #10
Purdy Swoft
Purdy Swoft's Avatar
That's a good thought, Charley !!!
Old 09-07-2019, 05:02 PM   #11
noyo55
Just joking about the C+ guys. Don’t take your selves so seriously !!
Old 10-01-2019, 04:47 AM   #12
lsr490
Just checking in for a little progress report.
Thanks
Old 10-01-2019, 10:41 AM   #13
Beater
Beater's Avatar
I was wondering how things were going. I was in for a B head, not sure now. whats stalling me out is how hard it is to get a water pump for a reasonable price for the B. should make a true B head that takes an A waterpump
Old 10-01-2019, 11:47 AM   #14
Charlie Stephens
What you are asking for is a high compression Model A head and that is already available in a configuration that is better than the original 1932 to 1934 head. Tod is definitely going down the right path with this project. His head will let the Model B owners run a stock appearing but high compression head in the their vehicles. Previously the 1932 Ford owners could run a high compression Model A head and use the Model A water pump (it places the fan belt in the correct location). The owners of the 1933-34 vehicles had a different problem. The water pump used on the 1933-34 four cylinder cars was shorter to allow for the slope of the radiator (see attached photo). This will give them a high compression head for their vehicles.
Charlie Stephens
Old 10-01-2019, 07:16 PM   #15
Tod
More castings are ready to be made.
Tod
Old 10-02-2019, 05:51 AM   #16
JRN1967
JRN1967's Avatar
Tod
Tod, I noticed in a past thread that you have a Mazak in your shop. Just wondering if you use it to make this B head?
JRN1967 is offline   Reply With Quote
Old 10-02-2019, 06:24 AM   #17
Tod
I'm not sure which Mazak you mean, but I am currently running all cylinder heads in my Toyoda Horizontal Machining Center. My new fixture design allows me to make heads with less set ups. I cut it from 3 to 2 set ups. In my new Mazak HMC I will be able to make blocks in 2 set ups as well.
Tod
Old 10-02-2019, 07:03 AM   #18
JRN1967
JRN1967's Avatar
Tod
I work tech support in the Northeast, it's good to read your Mazak's are part of the process.
John
Old 10-02-2019, 11:04 AM   #19
Beater
Beater's Avatar
Charlie Stephens
yes get that, I guess I can use a A head on the B block. well here is a question for the maker, Tod. if I drill the extra steam holes in the A heads that you make, will I run into the water passage or is it to thick in that area to be able to hit the water passage?
Old 10-03-2019, 06:15 AM   #20
Tod
It should be no problem hitting the water passage.
Tod
