02-03-2018, 09:25 PM | #1 |
Do's don'ts tricks
I'm the first to admit, I am a novice and have learned a great deal from reading/studying this site.
Thought it would be good idea for folks to list some of their things they've learned: Do - when changing water pumps: Use a 6 point socket, stainless steel bolts for the bolt in the lower water hose. Use a little grease to help hold the gasket in place when installing the new pumps. Don't fill with antifreeze - use water until your sure you have no leaks.
Thanks Andy 1952 F1 |
02-04-2018, 06:59 AM | #2 |
Re: Do's don'ts tricks
Do - when installing fuel pump, do it while with the fuel pump stand attached. Much easier.
Thanks - 30-9 1939, 1940 |
02-04-2018, 08:56 AM | #3 |
"Double check" to make sure you have installed your throwout bearing before install engine. It's easy to forget. I learned the hard way.
02-04-2018, 09:34 AM | #4 |
When installing your distribitor on your engine , cut heads off of 2 bolts of the proper size .put them in the holes for your distribitor to guide and align it up .turn the rotor as you slide the distr. in place install the 3rd bolt then remove the guide bolts and install the other bolts .
02-04-2018, 11:11 AM | #5 |
Don't strip down the light switch because you can't get the headlights to work, without first pulling the main fuse and cleaning the contacts. Amazed me that the car ran fine but the lights wouldn't work till I cleaned that up.
02-04-2018, 11:29 AM | #6 |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
02-04-2018, 11:47 AM | #7 |
"Learn as you go" is for fools. Study up before you pick up a wrench.
Alan |
02-04-2018, 12:23 PM | #8 | |
And the dang gasket stays in place while you fiddle-fart around with the whole gob of a mess (usually with the radiator in place) . . . |
02-04-2018, 12:27 PM | #9 | |
When I have a situation where I need high strength stainless, then I go to ARP and other suppliers - but the cost gets VERY high. |
02-04-2018, 01:36 PM | #10 |
When you install the rear main rope seal, remember to cut it "proud" and put on a dab of silicone on each surface before you tighten it in place.
02-04-2018, 02:30 PM | #11 |
great info
I was told chrome plated stainless is like a grade 5 or 8. may just be BS |
02-04-2018, 03:10 PM | #12 |
12cliff23 ( No. )
02-04-2018, 05:20 PM | #13 |
Anytime you have the oil pan off , drill out the rivets that holds the dipstick boss to the pan and re seal it. And never ever install the pre 8ba one piece oil pan without first installing the flywheel.
02-04-2018, 05:41 PM | #14 |
When installing hard to reach spark plugs, use a piece of fuel hose usually 5/16" slip it over the spark plug, and use it like a flex driver It can also remove them after you've broken them loose, but sometimes it don't work as well
02-04-2018, 07:57 PM | #15 |
Adjust the valves before installing your pistons and rings. Engine turns over real easy.
02-05-2018, 03:09 AM | #16 |
Always make sure the oil fill plug will come out before you remove the oil drain plug on granny's and rear ends.
Edit: I mean trannys but it might be wise on grannies as well! LOL Last edited by Fortunateson; 02-07-2018 at 10:10 PM. |
02-05-2018, 06:38 AM | #17 |
Always use you IPhone to take picture of any project as you take it apart so you will have a reference to put it back together.
02-05-2018, 07:18 AM | #18 |
Bagging and tagging as you go - not at the end of the session - prevents much confusion.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
02-05-2018, 07:27 AM | #19 |
When installing heads it helps to cut off a couple of old (long) head bolts to use as studs a to get it in place.
02-05-2018, 01:11 PM | #20 |
Yes, I use the ziplock freezer bags and a sharpie. amazing how soon you forget what those bolts were from
Short URL: http://smu.gs/14g7eDW |
