Old 09-30-2020, 07:34 AM   #1
Conaway2
Conaway2's Avatar
Default Rear wheel bearing dimension
Does anyone know what the factory spec inner diameter of the rear bearing housing is ?
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 09-30-2020, 10:18 AM   #2
katy
katy's Avatar
Default Re: Rear wheel bearing dimension
Do you mean the ID of the hub, where the bearing rides? Or?
Les Andrews book says: ID of wheel hub - 3.188" - 3.190" - min 3.185"
Old 09-30-2020, 12:37 PM   #3
Conaway2
Conaway2's Avatar
Katy - thanks - that’s exactly what I needed. My drum measures 3.182”.
Jim
