Old 10-07-2012, 03:59 PM   #1
wspiker
wspiker's Avatar
Default 1940 Ford Trunk Handle
Currently, I have to use the trunk latch key each time I open the trunk on my '40 Ford. How can I fix my trunk handle to remain unlocked and than lock it with the key when needed?
Thanks,
Daryl
wspiker is offline   Reply With Quote
Old 10-07-2012, 04:13 PM   #2
TJ
TJ's Avatar
Default Re: 1940 Ford Trunk Handle
They are all like that. I have an origianl handle and it must be locked to remove the key.
Old 10-07-2012, 05:02 PM   #3
40cpe
40cpe's Avatar
Grind the head of a spare key small enough that the spring loaded cover will fit over it. Leave it unlocked until you need to secure it.
40cpe is offline   Reply With Quote
Old 10-08-2012, 10:30 AM   #4
wspiker
wspiker's Avatar
Thanks 40cpe. I had a '47 Tudor with an original handle and I was able to keep it locked or unlocked. I bought a new chromed one and it was such that you needed to use a key each time to open the truck. I guess I should have switched the key lock?
Old 10-08-2012, 02:32 PM   #5
40cpe
40cpe's Avatar
I don't know about the '47, but I've never heard of anyone being able to remove the key from a '40 with the key cylinder in unlocked position.
Old 10-10-2012, 01:53 PM   #6
FlatHeadCoupe
FlatHeadCoupe's Avatar
I can modify your lock cylinder to allow removal of the key in the open position. Only requirement is that you have a working key and that the cylinder is a "Hurd" manufactured OEM cylinder (it would be chrome or nickle plated rather than the Briggs and Stratton stainless clad design). If you are interested in the modification, give me a call.
John at 919-559-5774
FlatHeadCoupe is offline   Reply With Quote
Old 10-10-2012, 02:26 PM   #7
Vic Piano
Vic Piano's Avatar
I don't know about the '40 but I can remove the key from our '39 CS trunk latch and it will remain unlocked, the same thing on our '47 Ford however, on the '39 LZ you have to lock the trunk to remove the key... Another Ford anomaly...
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 10-10-2012, 06:35 PM   #8
Hugh in NC
Hugh in NC's Avatar
I just did this modification to my '40 this past summer to make it easier to get the folding chairs in an out of the trunk. I did not document the procedure at the time, but it was very easy and straight forward. Take out the lock and look at it and how it works. There is a little tab somewhere that you can grind off and the trunk opens and closes without the key. You shouldn't have any problems.
Hugh
Hugh in NC is offline   Reply With Quote
Old 10-10-2012, 10:12 PM   #9
okiedokie
okiedokie's Avatar
Hugh
Except to lock it! Love that avatar.
okiedokie is offline   Reply With Quote
Old 10-12-2012, 07:14 PM   #10
wspiker
wspiker's Avatar
Thanks Hugh and John............and everyone. I'll gitter done.......... :-)
Old 10-13-2012, 01:35 PM   #11
boman5
I can remove my key locked or unlocked on my Drake handle. it may not be correct but sure is handy.
boman5 is offline   Reply With Quote
Thread Tools
Display Modes
