01-13-2021, 06:59 PM | #1 |
drip edge on 32 sedan
hi i'm looking for a little help in ideas to bend the drip edge on a 32 sedan. Any suggestions would be helpful thanks
01-13-2021, 08:35 PM | #2 |
Re: drip edge on 32 sedan
Are you using the reproduction aluminum or reproduction Steel? The process to do it successfully differs greatly.
01-14-2021, 09:04 AM | #3 |
using the steel one . funny they bend them for the 5 window but not the sedan. trying to find out the different ways to do it.
01-14-2021, 07:37 PM | #4 |
We used a straight length from United Pacific.
After tack-welding a section of 1 inch tube vertically to the welding table, the first attempt to heat the rain-gutter with a torch and bend it around the tube FAILED. The gutter wrinkled. The second attempt used the same tube on the table and gently created the curve by keeping the flat portion on the table and bending the gutter slowly around the tube at room temperature. This worked very well and recommend this process for United Pacific rain gutter. |
01-15-2021, 05:44 PM | #5 |
When I had my delivery conversion done at Kemp's the rear door drip rail came preformed from a guy out west. When we built my Vicky it needed new drip rails so we took some cherry ones off a 4 door I was parting out and the body shop reshaped them to fit the Vicky. If you want I can put you in touch with the shop that did the rails.
01-16-2021, 07:33 PM | #6 |
01-16-2021, 07:37 PM | #7 |
ttt
01-16-2021, 07:42 PM | #8 |
thanks for the help on this
01-16-2021, 09:00 PM | #9 |
It's always good when something comes out well. Good job!
