Old 01-12-2021, 02:42 PM   #1
Habusailor
Habusailor's Avatar
Default Power brakes
My 57 Fairlane 500 has power brakes. What are the 2 arms all about at the foot pedal? One is where the master cylinder arm hooks up the second one attached to the first with what looks like a pedal adjustment. Mine does not have a return spring on the system. My pedal is very close to the floor boards something doesn’t seem correct on this set up.
Habusailor is offline   Reply With Quote
Old 01-13-2021, 10:39 AM   #2
5851a
Default Re: Power brakes
https://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/qJ0AAOSwGJlZI9Fn/$_57.JPG?set_id=8800005007 Do you have all the pieces? If the link works thats the system that was used in a 58 I had think it's the same as 57.
5851a is offline   Reply With Quote
Old 01-15-2021, 08:18 AM   #3
KULTULZ
KULTULZ's Avatar
Post Re: Power brakes
You have the 1957-1960 KELSEY-HAYES SWIFT-SURE PB System. The pedal assy is unique to that system as the booster is mounted inside the firewall.
Full description and DIAGNOSTIC SEQUENCE will be in your SHOP MANUAL.
File Type: jpg BRAKE - SWIFT-SURE Power Assist _1 (3).jpg (56.4 KB, 14 views)
File Type: jpg BRAKE - SWIFT-SURE Power Assist _1 (4).jpg (84.0 KB, 14 views)
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
