01-03-2021, 02:30 PM | #1 |
Ford WWII bomb truck question
Found this picture in a book about Willow run. It doesn’t look like the “Burma Jeep’s” that were used in the war. Just wondering if these we’re V8 or sixes, and what truck it was based on?
01-03-2021, 03:00 PM | #2 |
Re: Ford WWII bomb truck question
Looks like a tonner.
I dig coal, which provides motivation for EVs. |
01-03-2021, 03:12 PM | #3 |
01-03-2021, 03:30 PM | #4 |
Can't see the grill very well but it looks like the front end is 1940/41 Ford 3/4T or bigger truck and I'd go with the V8.
01-03-2021, 04:53 PM | #5 |
Hood center trim looks wide like a 41, i would think more likely a V8. The picture almost looks like it has a chrome front bumper but that wouldn't make sense on a military truck, but then again it was either china or russia painted whitewalls on the missle carriers
01-03-2021, 05:16 PM | #6 |
01-03-2021, 07:25 PM | #7 |
Interestingly, according to Ford specs the model 19Y is a 1941 model-year 1-Ton Truck with 8-cyl 100hp engine and a 122" wb. chassis.
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 01-03-2021 at 07:51 PM. |
01-03-2021, 09:42 PM | #8 |
100 hp didnt arrive until the 59 ab i thought. merc motor?
01-03-2021, 09:58 PM | #9 |
1939 Mercury, first of the 100 hp engines
01-03-2021, 10:05 PM | #10 |
In the OP's photo I could swear it's all tonner gear, but looks less than the 122" wb. Picture it with a full cab and then the full rear fenders installed. Would there be room for a 17" (in my case a 34" tire), and still open the door?. The frame behind the rear axle has been bobbed off. It's really cool no matter what they did to build it. A short wheelbase vehicle certainly maneuvers better in close quarters. But ford spec says 122" . They should know.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
01-03-2021, 10:45 PM | #11 |
That "19Y" from above....the "1" indicates 1941 model year. The "9" indicates "Mercury" 239-type engine. DD
01-03-2021, 11:36 PM | #12 |
And then in '42 there were some jailbar versions. This could be similar to my current project I'm building on a 4x4 chassis....The same factory cowl I have and I plan on stealing that windshield design. Thanks for bringing these M1 trucks to light!
01-04-2021, 07:17 PM | #13 |
Prewar Mercury & optional truck V8s were 95-hp. The post war V8s were 100-hp. Some munitions haulers were V8 but some were G series 6-cylinder types. It depends on were they were made. There were several different sizes. There was one type built on the GTB chassis. Others on the G8T chassis. Those early ones were likely built by Ford of Canada since they were involved in the war early on. Ford-Dearborn likely started making them in 1942 but may have used the earlier chassis in smaller numbers before the US involvement. The US was tight with the purse strings until the lend lease act came into affect and a lot of that was going overseas for the allied efforts.
01-09-2021, 06:05 PM | #14 |
I stumbled across video on the web that mentioned a mission on Dec 27, 1941 a group of PBY Catalinas flew the first offensive mission on the US side of the war. Here's a grab of that video showing the name at the top at the time at the bottom if you want to check it out. There's nothing about the trucks other than this photo.
01-10-2021, 11:29 AM | #15 |
They did a lot of field expedient things during the war. The cats were used for anti sub warfare until a straight tail version of the B-24 called the PB4Y-2 Privateer finally came on line. The photo doesn't show the lift that was on top of the wing to hoist the bombs up unto the shackles. They would have been a pain in the back side to load but they could catch subs on the surface and do some damage to them. There used to be a bunch of PBY Catalinas based at the Corpus Christy NAS during the war. When I worked down at the Army Depot there back in the 80s, the old ramps that they used to get from the hangars into the water were still there but deteriorating. They could taxi them in and out of the water pretty easy.
