Old 01-02-2021, 10:58 PM   #1
bucket-o-rust
Default Brake shoes
When buying new brake shoes is it better to buy complete brand new ones or old relined ones ? I plan to buy them through Snyders Catalog. Thanks for any input.
bucket-o-rust is offline   Reply With Quote
Old 01-03-2021, 12:26 AM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: Brake shoes
I have seen the new shoes and they really look good. I would suggest the new ones with WOVEN linings. The woven linings make a big difference in how your Model A will stop. The molded linings are much harder and your car will not stop nearly as well.
The problem with original used brake shoes is most are either very badly rusted or the holes are all worn out. I usually have to go thru 20-30 used shoes to find 8 that are usable.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 01-03-2021, 12:35 AM   #3
Jack Shaft
Nice thing about woven is no dust,you can lube wedges,cams and rollers
Jack Shaft is offline   Reply With Quote
Old 01-03-2021, 06:31 AM   #4
updraught
updraught's Avatar
Whatever you buy make sure the linings fit your drums.
In some ways it is simpler to buy new drums fitted to hubs and machined, and new shoes and lining made to fit.
updraught is offline   Reply With Quote
Old 01-03-2021, 09:35 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
John, we lube both types of linings with a WD40 product, and dust has not been a problem for us.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-03-2021, 11:38 AM   #6
ericr
ericr's Avatar
I thought we decided in earlier posts that WD is only a water displacement, not a lubricant...
ericr is offline   Reply With Quote
Old 01-03-2021, 12:01 PM   #7
redmodelt
redmodelt's Avatar
There is more then one product put out under the WD label then WD-40. Besides, WD-40 would keep the water off the lining!
Old 01-03-2021, 12:18 PM   #8
BRENT in 10-uh-C
"We" did not decide that. Someone else might have thought/suggested that, but not "we". Anyone that suggests WD40 is just a "water displacement" is naïve about the brand.
BRENT in 10-uh-C
Old 01-03-2021, 01:10 PM   #9
Jack Shaft
The idea is to lubricate,the braking effciency is directly related to reducing friction in the moving parts.
