Old 12-28-2020, 06:50 PM   #1
Slowmotoring
Default Are aftermarket hoods any good?
Just looking to see if anyone Here has any experience with aftermarket model a hoods. My 29 is in need of a hood. I have a hood for it but the top passenger side is in pretty poor shape. I have looked some for a original hood but what i have found are similar in price to a new aftermarket hood. I plan on searching longer for a original hood since id rather have a car with parts from ford. But if it comes to it are the aftermarket hoods any good? Fit good?
Slowmotoring is offline   Reply With Quote
Old 12-28-2020, 07:43 PM   #2
GPierce
GPierce's Avatar
Default Re: Are aftermarket hoods any good?
I got a 30-31 hood from Brattons in 2016. It fit fine out of the box. A fine point judge could probably tell a difference but I can’t.
This is Brattons description: This is a very good quality hood made by ROOTLIEB CO. Best of two made. Includes steel hinge rods, handles and latch clips.
GPierce is offline   Reply With Quote
Old 12-28-2020, 07:51 PM   #3
Oldbluoval
Oldbluoval's Avatar
I’ve used 30-31 made by rootlieb with success
No report for 28-29
Oldbluoval is online now   Reply With Quote
Old 12-28-2020, 10:17 PM   #4
denis4x4
denis4x4's Avatar
I have a 28-29 one piece Rootlieb that is a perfect fit
File Type: jpg 90F3D6B8-0255-493B-A214-DBC572C0ECEB.jpg (85.8 KB, 37 views)
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 12-29-2020, 12:45 PM   #5
fivefix
fivefix's Avatar
I also have a Rootlieb hood I purchased through Snyder's. Fits like a glove.
fivefix is offline   Reply With Quote
Old 12-31-2020, 10:47 AM   #6
ronn
just buy the original..............
not like a model A is a rarity.
ronn is online now   Reply With Quote
Old 12-31-2020, 04:24 PM   #7
Oldbluoval
Oldbluoval's Avatar
Other than the ones I’m hoarding......
It’s been ages since I’ve seen a really good top.
Louvers are out there but tops are usually beat up, wallowed around, stretched, hinge broken and hard to shrink
If paying for the work, Rootlieb will save money
Old 12-31-2020, 05:31 PM   #8
john in illinois
john in illinois's Avatar
Another vote for Rootlieb. There are not many good used hoods here. A friend has looked at several,none worth bringing home.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 12-31-2020, 05:50 PM   #9
Dick Carne
Dick Carne's Avatar
I replaced the hood on our 1929 Town Sedan when I re-did it several years back - the hood fits fine. Also, when we built my nephew's '28 roadster pickup, we put a new hood on it with similar results. I offer this since these two models use different hood tops, and no one else seems to have commented on the '29 hoods - I couldn't tell whether your '29 sedan is a tudor of fordor and each uses a different hood design, I thought that I would offer these comments on both. Good luck. I don't think that you would go wrong with a new hood.
Dick Carne is offline   Reply With Quote
Old 12-31-2020, 09:03 PM   #10
Woodys29
I put a rootlieb hood on my 29 tudor about 40 or 45 years ago and it still looks real good. The best money you can spend on a model A
Woodys29 is offline   Reply With Quote
Old 12-31-2020, 09:41 PM   #11
Terry, NJ
Terry, NJ's Avatar
I have a good 29 hood. my hood has smooth sides as opposed to the "Briggs" hood that has the continuation of the Beltline from the doors across the gas tank and the across the hood. My 29 needed the belt line to be correct and the hood that was on it did not have it. I'm asking $150, sorry, No pics.
Terry
Terry, NJ is offline   Reply With Quote
Old 01-01-2021, 03:17 PM   #12
antiquepa
antiquepa's Avatar
I have an after market on my 1930, was on the car when I bought it. One side buckles when I raise it. I would never buy one, but for now i'm stuck with the one I have.
antiquepa is offline   Reply With Quote
Old 01-01-2021, 04:11 PM   #13
Oldbluoval
Oldbluoval's Avatar
Antiquepa.....
Do you know who made it? As above and with me, I’ve never had one problem with a rootlieb
Old 01-01-2021, 04:29 PM   #14
SteveB31
SteveB31's Avatar
I have hundreds of original hoods. Email me and I will pick out what you are looking for and send some photos.
Steve Becker
Parts@Modelastore.com
SteveB31 is offline   Reply With Quote
Old 01-01-2021, 04:44 PM   #15
Jeff/Illinois
Jeff/Illinois's Avatar
The biggest difference you see between an original '30-'31 hood and a repop is, the reproduction doesn't have the radius at the lower rear part of the hood to match the curve of the cowl in that area. They go straight down and stick out at the bottom.
Maybe newer ones are more like the originals the ones from the 70's were like that, lacking the curve.
Jeff/Illinois is offline   Reply With Quote
Old 01-01-2021, 04:58 PM   #16
frank55a
Years ago I got a Rootlieb for my 28 Tudor it was a perfect fit, while not judged in MARC or MAFCA fine point judging the A took an AACA Jr at Hershey and a Sr at the spring AACA National meet.
frank55a is online now   Reply With Quote
Old 01-01-2021, 07:24 PM   #17
antiquepa
antiquepa's Avatar
Post #13, Oldbluoval..Don't know whos after-market hood thats on the car, not on my Roadster, its on my 1930 4 door A, AND JUST ONE SIDE KIND OF BUCKLES WHEN YOU OPEN IT.
Old 01-01-2021, 11:38 PM   #18
Kevin in NJ
The repro hoods are decent and workable from reports of people with them.
I have looked at them and the difference is the sides are flat. The factory hood is slightly curved to match the rad shell and curved more to match the cowl sides. The curve is also part of the raised area and the louvers. The repros are flat so they can never quite match the curves front or rear so there will be slight gaps. If you know what you are looking for you can tell it is a repro from a short distance.
I believe the top panels are not correctly shaped. You have to bend them to get them to fit.
What kind of a restoration are you doing and what do you 'need' to have. Personally I feel the factory clean fit is a better look as the repro always looks off once you see it.
I am sure Steve Becker has some nice original hoods and he does have a great reputation.
Cabriolet and Technical Hints
Kevin in NJ is offline   Reply With Quote
Thread Tools
Display Modes
