Old 12-12-2020, 12:37 PM   #1
2935ford
2935ford's Avatar
Default Rear Brake Arms Orientation
Which is correct?
Les Andrews book shows the right brake arm but supplier shows a different picture of the right arm?
Does the arm where the rod attaches curve in towards the backing plate as per Les or away towards the center of the rear axle as Supplier lists?
Thanks.
2935ford is offline   Reply With Quote
Old 12-12-2020, 01:18 PM   #2
Brentwood Bob
Default Re: Rear Brake Arms Orientation
Orientation is different in each picture.
Same lever.
Brentwood Bob is offline   Reply With Quote
Old 12-12-2020, 02:10 PM   #3
2935ford
2935ford's Avatar
Where it attaches and is pinned to the cam shaft, one side of the arm at the hole is flat the other side is slightly tapered around the hole?
To orient mine to Les Andrews book, my tapered side faces towards the backing plate?
Mine are marked with raised letters "LH" and "R" on the arms bottom.
So, to orient the Suppliers picture to Les Andrews book, they are marked incorrectly?
R s/b L and L s/b R?
Or, I have the wrong arms for an A?
Old 12-12-2020, 06:43 PM   #4
SteveB31
SteveB31's Avatar
They lean towards the backing plate. Also, they , when installed, point inward towards the brake cross shaft.
SteveB31 is offline   Reply With Quote
Old 12-12-2020, 08:02 PM   #5
2935ford
2935ford's Avatar
SteveB31
Thank you.
