12-07-2020, 01:37 PM | #1 |
Quick question re valve springs.
Hello!
Just a quickie. If you have a valve spring with closely wound coils at one end only, should the end with the tightly wound coils go towards the guide, or the keeper?? Or does it not matter which way around they are fitted? Thanks in advance. Mart. |
12-07-2020, 02:20 PM | #2 |
Re: Quick question re valve springs.
Mart the closely wound end of the spring goes towards the retainer/ keeper end.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
12-07-2020, 02:28 PM | #3 |
Thanks Ronnie. I used 8 of these valve springs and got 7 the wrong way around!
Got a little rework to do! Mart. |
12-07-2020, 06:29 PM | #4 |
12-07-2020, 07:44 PM | #5 |
The tight wrapped coils go on the guide, or another description, against the block, or up.
12-07-2020, 08:12 PM | #6 |
12-07-2020, 08:17 PM | #7 |
I've always put the close would end to the guide. Less mass of the spring to control.
12-07-2020, 08:30 PM | #8 |
Yes, the tight wound end goes up against the guide.
12-07-2020, 09:21 PM | #9 |
12-07-2020, 10:55 PM | #10 |
Yes, close wound coils to the stationary end of the spring.
Terry
12-08-2020, 03:15 AM | #11 |
Thanks for all the input, fellas. I'll go with the consensus.
Mart. |
12-08-2020, 10:11 AM | #12 |
