#1 |
How do you get these felt seals to fit neatly in the groove of the "clam shells" . The new felts looks far too big and loose in their uncompressed state.
#2 |
The felt seals should be rectangular not square. The narrowest width should fit into the clam shell slots with a little help.
#3 |
I've cut strips of cork gasket material to lay in the groove to take up some of the space making them fit tighter. I use a little bit of silicone gasket maker to stick the cork into the bottom of the groove and a bit of the same to stick the felt to the cork. This makes for a better compression fit when assembled. I do not use the gasket maker on both sides of the felt so it still has the ability to move/slide as needed while going down the road.
Dave / Lincoln Nebraska It'll feel better when it quits hurting. |
#4 |
Try soaking the felts in motor oil.
Bob Bidonde |
#5 |
I took the back axle and drive line out of a 29 tudor which had been flooded for a week or so ,halfway up the windshield in fact . The vehicle had been in one family since new and had 76,000 miles on it . It had never been apart I would bet . There was no felt in the clam shell grooves just a tight fitting cork seal . I never have much success with those fluffy felt seals poked prodded greased etc etc etc I tried cork in my 28 phaeton and no leaks (yet !!!)
John in rainswept Suffolk County England . |
#6 |
https://www.ebay.com/itm/Model-A-For...AAAOxyY9VRQWmB |
#7 |
I use the o ring upgrade also and have not had any leaks.
Thread Tools | |
Display Modes | |
