Old 04-24-2020, 01:43 PM   #21
PalAl
PalAl's Avatar
Default Re: Insulation material
I'm in the process of insulating now, I used a productt from Speedway Motors
You have a choice of single or double sided
https://www.speedwaymotors.com/Alumi...ded,32193.html
https://www.speedwaymotors.com/Alumi...eets,2604.html
The tape helped with sealing the seams
https://www.speedwaymotors.com/Alumi...Ft-,94554.html
I undercoated the inside of the body before installing the insulation.
Last year the front of the car was completed, firewall, cowl sides, floor, doors and under the seat. I noticed a huge difference in sound and heat in the car, and the undercoating has rid the "tinny" sound when you close the doors. So seeing I have some extra time on my hands..... thought I would do the rear and complete the job.
I got the cans of undercoat at my local farm store.
File Type: jpg Insulation tape from Speedway resized.jpg (65.9 KB, 48 views)
PalAl is offline   Reply With Quote
Old 04-24-2020, 08:30 PM   #22
lsr490
Originally Posted by 30 Closed Cab PU View Post
lsr490 - Thanks for the tips/info. I tried the link you posted in post 6 - get a 404 page not found error.
Try this one.
https://www.usenergyproducts.com/col...ore-insulation
"Avoid Model A Mythsteries. Read, study and challenge ALL advice with current logic, chemistry and technology!" author unknown
lsr490 is offline   Reply With Quote
Old 04-24-2020, 09:22 PM   #23
30 Closed Cab PU
LSR490 - Thanks, interesting it has foil on both sides.
30 Closed Cab PU is offline   Reply With Quote
Old 04-24-2020, 09:37 PM   #24
Dave in MN
Dave in MN's Avatar
I used X-mat sourced from Eastwood for sound deadening. Very easty to work with. Then sprayed 3-M High Strength contact adhesive on it and adhered bubble wrap double faced aluminum insulation that was about 1/4" thick. I even put it in the roof assembly between the wood ribs. The double faced bubble insulation was sourced from a local Menards. (Like Home Depot or Lowes) Both help greatly.
Good Day!
Dave in MN is offline   Reply With Quote
Old 04-24-2020, 09:40 PM   #25
Dodge
And don't forget that adding Dynamat will add at least 80-100lbs. to the car.
Dodge is offline   Reply With Quote
Old 04-25-2020, 12:15 AM   #26
Ruth
I don't think so. A bulk pack of Dynamat Xtreme weights ~15-20 lbs. I used a little less than two boxes for the interior of my Town Sedan, excluding the firewall and roof.
Ruth
Old 04-25-2020, 12:48 AM   #27
CC-Mo
CC-Mo's Avatar
Originally Posted by Y-Blockhead View Post
I had thought about that also. The Dynamat REALLY sticks and if you pay attention to sealing it, especially around the edges, I don't see how moisture could get behind it (but I suppose anything is posible). They sell a little wooden roller to seal it flat.
Also in the pictire below, you can see the top of the Dynamat is above the bottom of the window so any water getting past the window seal will flow on the outside of the Dynamat.
And lastly, it doesn't rain much in SoCAl. And when it does I don't drive the Ol' Girl.
That Sir is one well sorted out car. Congrats.
Southern Missouri
'30 Tudor sedan, Original
'33 5-Widow Coupe, Henry Steel, Merc Flathead, 50's Hotrod style.
CC-Mo is offline   Reply With Quote
Old 04-25-2020, 01:17 AM   #28
Y-Blockhead
Y-Blockhead's Avatar
Thank you! That means a lot to me.
Old 04-25-2020, 10:07 PM   #29
bdtutton
Originally Posted by lsr490 View Post
It's not glued, just lies on top of the floorboards with the floor mat placed on it.
Don't be fooled by the glare from my LED light the firewall is a black ABS insulated panel.
https://www.snydersantiqueauto.com/P...earchByKeyword
Hello....I noticed you installed a FIREWALL INSULATOR from Snyder's. How hard was it to install and did it keep out sound and heat as advertised?
bdtutton is offline   Reply With Quote
Old 04-25-2020, 11:25 PM   #30
PalAl
PalAl's Avatar
I installed the firewall insulator last year when I insulated the front "cab" section of the car. FW insulator was the first part of the job, needed a little trimming and different bolts for the junction box, removel of choke rod and gas line and any other "things" you may have tucked out of site. BIG difference in sound and heat, made my wife very happy. Even better results with the cowl and floors undercoated and insulated. I would go for it. See post #21 for what I used, I'm doing the back half of the car now.
Old 04-26-2020, 06:59 AM   #31
RTPbee81
RTPbee81's Avatar
Any concerns on what this does to the body panels when the next owner wants/needs to do a full restore? is this adhesive easy to remove?
RTPbee81 is offline   Reply With Quote
Old 04-26-2020, 07:38 AM   #32
dmaxweb
dmaxweb's Avatar
Tell them it's a rare factory original "quiet ride package" option
dmaxweb is offline   Reply With Quote
Old 04-26-2020, 08:41 AM   #33
30 Closed Cab PU
Another factor is if it is to be sold, makes it difficult for buyers to inspect for internal rust.
Old 04-26-2020, 10:04 AM   #34
Bob Wright
Bob Wright's Avatar
Tom,
When doing the restoration on early Victoria I installed a Dyna-mat kit from L.B.& B. Boy was I pleasantly surprised @ how well it quieted the interior & keeping it more temperature tolerant in the cab. Adding to lowering the heat & sound from the engine,I also installed a insulating panel on the inside of the firewall.
Worked for me,
Bob
Bob Wright is offline   Reply With Quote
Old 04-27-2020, 08:07 PM   #35
whirnot
whirnot's Avatar
I use Fatmat in my roadster, Motorhome, and my wife's 51 F1.
I believe it is similar to Dynamat. It quiets a lot and does keep it cooler. I am restoring a 30 pickup and it will get Fatmat everywhere I can get it.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 04-28-2020, 01:50 AM   #36
dumb person
dumb person's Avatar
May have to remove with dry ice.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
