Old 12-11-2018, 03:33 PM   #1
Grandad Pete
Default 29 CC Pickup, loose hinge pin fix wanted.
Having replaced the pins I find that on a couple of hinges, the splines are not holding in the top of the hinge due to the holes being worn.
Is there an easy barn yard 'back in the day' type fix to hold them in place or will i have to braze up the holes and re drill them back out to the correct size?.
All help and advice will be gratefully received.
Grandad Pete is offline   Reply With Quote
Old 12-11-2018, 03:38 PM   #2
Lawrie
Lawrie's Avatar
Default Re: 29 CC Pickup, loose hinge pin fix wanted.
If you want a barn yard fix, just squash the knurled part of the pin out of round a bit
Lawrie
Lawrie is offline   Reply With Quote
Old 12-11-2018, 04:27 PM   #3
oldforder
oldforder's Avatar
How about some JB weld on the pin before installing it? Or just add some brass to the pin rather than the hole.
oldforder is offline   Reply With Quote
Old 12-11-2018, 04:41 PM   #4
CHuDWah
CHuDWah's Avatar
Not a "backyard" fix but the Model A parts houses sell oversize pins
CHuDWah is offline   Reply With Quote
Old 12-11-2018, 09:38 PM   #5
CarlG
CarlG's Avatar
Check out this repair kit:
https://www.ebay.com/itm/FORD-MODEL-...jcnD:rk:1:pf:0
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-11-2018, 11:00 PM   #6
SeaSlugs
SeaSlugs's Avatar
Thats what i would do...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 12-12-2018, 07:27 PM   #7
Roadster62
Roadster62's Avatar
Originally Posted by CarlG View Post
Thank you! That looks like a good deal, Proper sized reamers might work better than a drill bit in oval, worn holes.
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 12-13-2018, 01:36 PM   #8
CHuDWah
CHuDWah's Avatar
Educate me how that works. I get that you drill out the hinge, then insert the sleeve and pin. But what's the threaded rod and nuts/washers for? "Pressing" in the sleeve?
Old 12-13-2018, 01:46 PM   #9
CarlG
CarlG's Avatar
Since I have never used this kit myself, I would suggest that you contact the seller: [email protected]. 408-722-2518. Dave is a very personable guy and an excellent machinists.
Alaskan A's
Old 12-13-2018, 11:15 PM   #10
Benson
Benson's Avatar
Default Re: 29 CC Pickup, loose hinge pin fix wanted.PINS are 0.243 NOT 0.250!!
I have posted this before.
For what it is worth here is a problem I had when removing pins to install mirrors.
I tried without success to remove the first pin ... it just would not budge. I did succeed in damaging the hole in hinge.
Then I bought one of the pin removal tools and the pin came right out "as slick as butter".
What I found out was that the original pins on the coupe measure 15/64ths or 0.243 and over size pins from vendors are 0.250.
I was using a 1/4 inch (0.250) drift to try and knock out the pin ... 0.017 too large, which was the reason I had so much problem with driving out the pin.
Note the pins, of 3 different lengths, that came with the pin removal tool are 0.243 not 0.250!
I never did find a drift of size 0.243!!
NOTE: As I remember certain models use different diameter pins.
Benson is offline   Reply With Quote
