Old 06-04-2017, 09:25 AM   #1
Afordman31
Afordman31's Avatar
Default Removing ridge from cylinders
It appears that I must have steel sleeves in my 1937 flathead. My ridge reamer will not cut the ridge. Any suggestions on how to remove the ridge to get the pistons out? thanks
Afordman31 is offline   Reply With Quote
Old 06-04-2017, 10:41 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Removing ridge from cylinders
Just wondering why your ridge reamer won't do the job?
Can you post a photo of your reamer and ridge set up?
Old 06-04-2017, 12:01 PM   #3
Afordman31
Afordman31's Avatar
I have ordered a new carbide cutter for the reamer but haven't received it. Thanks
Old 06-04-2017, 12:12 PM   #4
Kube
Kube's Avatar
The sleeves are too hard for a ridge reamer.
I have to ask: If you have ridges, why are you worried about removing them? It's obvious the bores are worn too far to simply replace rings and machine work is necessary.
If you are attempting to salvage the pistons from an otherwise poor block, use a small die grinder to cut away the ridges.
Old 06-04-2017, 12:59 PM   #5
scrapiron
What you have in your hand is a HONE,,,what ever the package says.
scrapiron is offline   Reply With Quote
Old 06-04-2017, 02:47 PM   #6
JSeery
JSeery's Avatar
Looks like a ridge reamer to me?
Old 06-04-2017, 02:55 PM   #7
zzlegend
zzlegend's Avatar
Me to. Not a hone.
zzlegend is offline   Reply With Quote
Old 06-04-2017, 03:28 PM   #8
scrapiron
OK,,,,,,,,,,never seen one like that,,,
Old 06-04-2017, 03:52 PM   #9
Bored&Stroked
Bored&Stroked's Avatar
I haven't used one in years . . . and don't see much of a purpose as when the cylinder is that worn, I'll rebore it to a larger size . . . or put new sleeves in it. Have you measured the bores to figure out how worn they are?
Old 06-04-2017, 04:47 PM   #10
Ggmac
Just a guess , he wants to resleeve and reuse Pistons . No sense in busting up some Pistons that may have a new home .
Ggmac is offline   Reply With Quote
Old 06-04-2017, 05:39 PM   #11
JSeery
JSeery's Avatar
If sleeves are that worn it is hard to believe the pistons are usable.
Old 06-04-2017, 08:48 PM   #12
flatjack9
flatjack9's Avatar
At the very least, the ring lands will be worn.
Old 06-04-2017, 09:02 PM   #13
V12Bill
V12Bill's Avatar
Steel sleeves and aluminum pistons. Which is going to wear the most?
V12Bill is offline   Reply With Quote
Old 06-04-2017, 09:28 PM   #14
Jack E/NJ
Jack E/NJ's Avatar
V12Bill>>>Steel sleeves and aluminum pistons. Which is going to wear the most>>>
Hmmm? Sounds like a trick question. I'll guess the sleeves the most. The pistons least. And the rings in between. Did I guess right? 8^) Jack E/NJ
Jack E/NJ is online now   Reply With Quote
Old 06-05-2017, 07:50 AM   #15
Kube
Kube's Avatar
x2.
Of course, from what I read on the Barn and other forums, most guys don't really "rebuild", at least not correctly.
Old 06-05-2017, 08:02 AM   #16
flatjack9
flatjack9's Avatar
I believe the pistons used with the steel liners were also steel.
Old 06-05-2017, 08:07 AM   #17
Bored&Stroked
I looked at the pictures that were posted earlier - pretty heavy ridge is visible. The sleeves look like the ole' "tin can sleeves" that Ford would put in many of their early 24 stud - 221 cubic inch Ford engines (though I didn't know they did it back in 37 - maybe a later 'rebuild'???).
Me, I would look for a new set of sleeves and associated pistons/rings . . . and rebuild it to tip-top shape. With that said, I'm not trying to spend your money - just talking about the best way to do the job.
Best of luck,
B&S
Old 06-05-2017, 09:09 AM   #18
chap52
chap52's Avatar
Go borrow one from Autozone and see it will do the job.
chap52 is offline   Reply With Quote
Old 06-05-2017, 09:35 AM   #19
V12Bill
V12Bill's Avatar
Remove sleeves and bore to 239 CID
Old 06-05-2017, 10:03 AM   #20
Kube
Kube's Avatar
I've done that and wow, well worth it. And, from my experience I got a stronger engine with less of an investment than R&R sleeves.
