11-28-2020, 05:31 PM | #1 |
A and AA flywheel castings
I have several flywheel cover castings for Model As and they have the side mount provisions for the frame mounts. I also have what I think is an AA flywheel cover and bell housing, with a socket on the bottom for the wishbone ball and the flange for a truck 4 speed transmission. but it does not seem to have side mount provisions like those on a car's casting. Is it supposed to bolt to the car-type casting, or what?
11-28-2020, 05:34 PM | #2 |
Re: A and AA flywheel castings
could be tractor
11-28-2020, 07:00 PM | #3 |
The AA uses the same flywheel housing as the A, the picture is an AA clutch housing.
11-28-2020, 09:29 PM | #4 |
No Ford tractor ever used a Model A engine or bell housing. There were some aftermarket tractors such as the Worthington mowers that used regular Model A stuff and industrial/agricultural power units based on the A but no Ford factory built tractors based on the A. |
11-29-2020, 02:07 AM | #5 |
I have always called that housing the bell housing which is bolted to the clutch or flywheel housing which has the mounting attachments to the frame.
11-29-2020, 10:44 AM | #6 |
11-29-2020, 11:34 AM | #7 |
It is likely for later then Model A. The 4 speed transmission was used for 30 years, but had different clutch housings for each year it was used. If you posted a photo, I could likely identity it for you.
11-29-2020, 11:52 AM | #8 |
I've always called it a bell housing also but Ford called it a clutch housing 7501.
11-29-2020, 07:12 PM | #9 |
Thank you all for your responses. I will verify in the next few days.
