Old 07-24-2020, 07:36 PM   #1
46woodie
Default Stromberg carbs
There is a sale coming up with 3 identical Stromberg carbs for sale. I dont really see any large ID like a #97 or other common logo on side. It would appear it was part of a tri-power set up . I dont have way to send pics but are they worth picking up JUST because they're Stromberg? I suppose the price would vary greatly depending on model. Any suggestions? Thanks
46woodie is offline   Reply With Quote
Old 07-24-2020, 09:39 PM   #2
Brian
Brian's Avatar
Default Re: Stromberg carbs
Maybe they are Stromberg 48's?
Do they have the summer/winter positions for accel pump?
Old 07-24-2020, 10:19 PM   #3
46woodie
I will have to take a closer look at the accel pump tomorrow. Looking for carbs for 46 Ford, wondering if these would be a good match. No idea what year these are or model #,will look into tomorrow
Old 07-25-2020, 10:36 AM   #4
scicala
scicala's Avatar
I believe Stromberg 48's were used in '34 and '35, and 97's used from '36 thru '38. In '39 started the Holley/Ford 94 style carbs used through 1956.
Sal
scicala is offline   Reply With Quote
Old 07-25-2020, 11:36 AM   #5
46woodie
Thanks Sal! Without markings its hard to know what they are. I hear about Strombergs used on later Ford dual/tri carb set ups and thought someday I could always try it.
Old 07-25-2020, 01:56 PM   #6
nickthebandit
What numbers are on the passenger side of the carburetor bowl ? 31/32 denotes a Stromberg 97, 1 1/32 denotes a Stromberg 48, 13 /16 denotes a Stromberg 81.
nickthebandit is offline   Reply With Quote
Old 07-25-2020, 02:08 PM   #7
supereal
supereal's Avatar
The reason the Stromberg 97s were only used for three years is that they are difficult to repair and adjust, particularly in twos or threes. They became popular because three would fit on a hot rod manifold with the stock generator. At our shop we recently rebuilt
a 97, and I had to search for my special tools from my hotrod days in the early 50's.
supereal is offline   Reply With Quote
Old 07-25-2020, 02:14 PM   #8
Mr 42
Mr 42's Avatar
No reason to work with old overpriced worn out Stromberg carbs.
You can buy new here.
https://www.stromberg-97.com/
Bolt on adjust idle and drive.
Mr 42 is offline   Reply With Quote
Old 07-25-2020, 04:00 PM   #9
46woodie
AHA!! 1 1/32 is on side of bowl. Ok guys, these appear to be in excellent rebuilt condition with all parts present. What would be a fair price? Sounds like I would have to use offset generator setup with these carbs? Thank you!!
Old 07-25-2020, 04:25 PM   #10
Tim Ayers
Yep. 48's.
If this helps, I bought an unused Uncle Max rebuilt 97 from a member here for $125. I know this was a good deal, so that is the low end.
To have Uncle Max rebuild my two excellent 97's two years ago was $205 a piece so that gives you an idea of what it cost to rebuild a core that does not need parts.
Tim Ayers is online now   Reply With Quote
Old 07-25-2020, 10:01 PM   #11
nickthebandit
Having Uncle Max rebuild the carburetors is still less expensive than buying new reproductions, and you will have the satisfaction that they will work the first time you use them. Also the satisfaction of using original ford carburetors.
