Old 04-08-2013, 11:09 AM   #1
Red Ryder
Default Round speedometer
The speedometer out of my 30 coupe shows 5mph slow compared to a GPS. Itook it out of the case & there appears to be an adjustment screw on the back side, is that possible? Can it be adjusted & how.
Red Ryder is offline   Reply With Quote
Old 04-08-2013, 01:56 PM   #2
Sparky
Sparky's Avatar
Default Re: Round speedometer
Hi Red,
Do you mean you have disassembled the speedometer or just removed it from the dash plate? The screw on the back of the speedometer case just holds the inner mechanism to the case and doesn't adjust anything.
It is possible to adjust the speed slightly, refer the the instructions here:
http://www.modelahouse.com/tech/spee...r/fischer.html
Also, if the mileage reading is incorrect per the odometer, as well as the speed, the problem may be an incorrect drive gear.
Sparky is offline   Reply With Quote
Old 04-08-2013, 02:08 PM   #3
Red Ryder
Yes I disassembled & noticed a small set screw, won't turn, on the back side. Thanks for the instructions. Red
Old 04-08-2013, 02:45 PM   #4
Mark in MT
To adjust the calibration, you need to balance the strength of the rotating magnet and the hair spring on top of the speed cup. There is a slide lever on the bottom side of the magnet which will increase or decrease the pull on the speed cup. In order to get the unit in calibration, you need something to turn the speedometer at a known rpm. 1000 rpm is equal to 60 mph. You can make the speedometer read correct at any one speed by just adjusting the hairspring, but it will not be accurate over a wide range unless you adjust both the magnet and the hairspring. If the magnetic pull cannot be adjusted high enough, then the magnet will need to be recharged.
All this is assuming that the odometer is reading correctly, meaning that the tire size and rear end ratio is correct.
Mark's Model A Service
www.marksspeedometer.com
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
